Online Now [156]:
Visitors: 155
Today: 12040
Total: 155804173
Forums › The Car › 206 Problems › Can't start?
Can't start?
Triggerfish
PostPosted: Tue Mar 21, 2017 6:40 pm Up
Car didn't start the night before first time. Started 2nd thereafter.
Next day, didn't start at all.
Battery is 12.3v
Checked the fuses, all ok.
(PUG 206 1.1L 2002)
Fuel pump has power of 5v. But no "Amps" when cranking? Can't hear any noise from the pump?
Any ideas?
Is there a special relay somewhere?
Is there a fuel cut-off switch?
Immobiliser issue?
206: 1.1L, 2002.
commandosqueak
PostPosted: Fri Mar 24, 2017 8:48 pm Up
Battery is flat. should be 12.7
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
Triggerfish
PostPosted: Mon Apr 17, 2017 8:35 pm Up
Turns out it wasn't the battery.
It was a broken wire.....from the fuse box to the ECU. No response from ECU either.
The 16 pin connector unit (below Fuse 15 - oxygen sensor/engine control unit/air flow sensor/ignition coil/injectors 30A).
PIN 13 (white/red wire) connected to ECU (connector 3-towards front of car) PIN F/2 had failed a continuity test.
Wire just rusted and broken, just under the battery low side.
Now solved.
206: 1.1L, 2002.
