Online Now [484]:
Visitors: 483
Today: 118822
Total: 153992404
Forums › The Car › 206 Problems › 2.0 HDI various Issue
andy1957
PostPosted: Tue Apr 18, 2017 5:51 pm Up
hi everybody I have a 206 2,0 hdi turbo which has now been in my back garden for 2yrs I paid one hundred for it .at first the brakes were shoot did them then it would not start. so I got a new in tank pump .and glow plugs .yeees it started now I have stop light handbrake light passenger airbag light and abs light any help would be grateful thanks.
VorTechS
PostPosted: Wed Apr 19, 2017 7:56 am Up
Staff - Vortechs
Hi. Not sure why you didn't start your own thread... so I did it for you.
Sounds like you need a code read to see what's up!
PostPosted: Sun Apr 23, 2017 2:42 pm Up
Well before I answer your questions,can you drive the car or not?if you can drive it,that is a good thing,and since it been sitting in your back garden for 2 years,I think you need to make sure that,you have a very good battery,and battery connection,so you can move to fixing the problems you have.
as for the Stop light and handbrake light,you need to check the level of the brake fluid as I'm sure it's kinda empty,and since you done the brakes,you need to refill it,if it's full then you have a faulty brake fluid reservoir leveler.
passenger airbag on,maybe the previous owner has turned off the pass. airbag,which make the light goes on on the dash so that you know it's off.
ABS light,if you have not drive the car yet,drive it ,as it might clear itself,if not,you need to get it checked,as it would be one of the sensors is faulty.
Good Luck.
andy1957
PostPosted: Sat Apr 29, 2017 5:24 pm Up
Embarassed thanks for the info .yes it is driveable .and I will ckeak fluid reservoir .well the prolem now is the obd 2 port having brought a diagnostics tab the obd2 port wires have snapped off and I do not know where the the wires go. Embarassed
