Latest: evert
Overall: 17112
Online Now [28]:
Visitors: 28
Today: 4476
Total: 93726670
Forums › The Car › 206 Problems › Peugeot 206 2.0 HDI problem
liaar_BIH
PostPosted: Sat Apr 22, 2017 11:34 am Up
Hi guys, need your help here.
Recently I've bought a used 2001 Pug 206 2.0 HDI, and I've noticed 2 strange mishaps.
1)
When I start the engine cold (let's say when going to work), it starts to loose revs (like i'm releasing clutch), and greyish smoke is going out of exhaust.
In the other side, when I start engine warm, there are no problems like that, works like charm. And even when cold it starts with no problems, no problems when starting the engine.
2) Today I turned on my car so oil doesn't get chunky (drivers licence impounded xD), and the traction control light was on when i started engine, and was on untill I started moving my car. When I stopped, held my brake down and it showed again.
Hope someone of you guys knows any of these errors...
PostPosted: Sun Apr 23, 2017 3:15 pm Up
Well for the first problem,you need to replace the glow plugs,and check if the relay is working or not,as grey smoke is un burnt diesel,when you got the glow plugs replace it will have the normal temp on a cold start.
