Latest: ArtistKS
Overall: 17145
Online Now [109]:
Visitors: 108
Today: 20354
Total: 115893354
Forums › The Car › 206 Problems › Pug206sw 2003 2hdi - Dipped Beam won't turn off
tri_94
PostPosted: Sat May 27, 2017 12:19 pm Up
Hi there have an issue with my pug206 sw 2003 2lt hdi
My dipped beam is permanently on. I have to disconnect the battery to stop it. The moment battery is reconnected it's back on. Tried fiddling with indicator stick and lights on off etc and still it remains on.
Has anyone any ideas or anyone had this issue before?
Everything seems to work as it should.
Nick
mtempsch
PostPosted: Sat May 27, 2017 1:09 pm Up
Nick
Going by diagram 4 here it would mean one of the relays in the engine fusebox is stuck (or always told to be) on, or there's a short bridging power across the relay switch or downstream of it.
Silvermetallic 2004 206 RC
tri_94
PostPosted: Sat May 27, 2017 3:14 pm Up
Thanks for the reply. Can you tell me roughly where I'd find them and how many relays I'd expect to see.
Nick
tri_94
PostPosted: Sat May 27, 2017 3:20 pm Up
tri_94
PostPosted: Sun May 28, 2017 11:47 am Up
Nick
tri_94
PostPosted: Sun May 28, 2017 5:00 pm Up
If I remove fuse 9 and 10 from BSI the dipped beam goes off
