Posted: Fri May 26, 2017 3:58 pm |
Hi all
I accidentally put on the headlights before starting the car, and both dipped beams are no longer working. I've checked and changed bulbs and the fuses are fine.
Any ideas? Did I blow something?
206 hdi 2005
Posted: Fri May 26, 2017 5:09 pm |
Reboot the BSI unit.
Ive seen this bug before.
Posted: Fri May 26, 2017 5:39 pm |
I did a BSI restart procedure! Still same issue!
By that you mean the standard shutdown, battery disconnect, reconnect, sidelight business right?
Posted: Mon May 29, 2017 7:31 am |
Bump?
I put a multimeter on the connection and nothing!
Posted: Tue May 30, 2017 11:47 am |
A faulty engine fuse box,check it correctly,if all is good,then you might have a faulty headlight stalk
Posted: Tue May 30, 2017 5:16 pm |
Timon2210 wrote: |
A faulty engine fuse box,check it correctly,if all is good,then you might have a faulty headlight stalk |
Is there a relay or something in the stalk that would have blown?
Posted: Wed Jun 14, 2017 11:57 am |
DJ- wrote: |
Timon2210 wrote: |
Is there a relay or something in the stalk that would have blown? |
No...but have you checked the under dash fuses?
