Forums › The Car › 206 Problems › Lower rear engine mount polybush bush replacement |
Posted: Tue Jun 06, 2017 8:19 am |
Has anyone replaced this bush with a polybush? If so do you have to remove the original bush surround i.e. the bit that's pressed into the bracket?
I'm thinking rather then remove the bracket and driveshaft etc I could leave it on the car, gut the original bush and fire in a polybush.
I've e-mailed the bush manufacturers but not heard back from them yet.
Posted: Fri Jun 09, 2017 10:38 am |
Posted: Mon Jun 19, 2017 5:38 pm |
did mine with a hammer and chisel just watch out for the oil level sensor costs a bit when you hit it by accident
Posted: Tue Jun 20, 2017 11:23 am |
I'd do it properly...i.e. take it off the car and press the new one in.
