Online Now [262]:
Visitors: 261
Today: 117568
Total: 155986917
Forums › The Car › 206 Problems › Fuel leak when filled up
stretchie_
PostPosted: Tue Jul 25, 2017 7:04 pm Up
Hi guys
Been registered for a bit but mainly a lurker.
The Mrs has had her 206 1.4hdi for about 3 months now and she just tops it up with £20 when she needs to. She started a new job today so we went to fill it up for her, after I stopped pumping the fuel I could hear fluid runnning, so looked under the car and the diesel was flowing out from under the car like an open tap.
It did stop after a bit so the leak is somewhere at the top. I'm hoping it's just the fuel neck to tank hose has split or the jubilee clip has broken.
I couldn't find anything in the search but is this a common issue?
Any ideas where to look apart from:
-Get the rear wheel off and the mud guard to check the hose
-Have a look u der the boot floor or under rear seats for the fuel pump cover to check that
Cheers
cainw1
PostPosted: Wed Jul 26, 2017 5:42 am Up
I had this happen on my 306 diesel when i overfilled it, it ended up splitting the filler hose pipe where it goes down into the tank. Was a hot day
gazza82
PostPosted: Wed Jul 26, 2017 11:58 am Up
There are some small overflow and return hoses and my guess one has split or come apart. It's all plastic now.
There is a difference from pre-plex and multiplex cars
Pre-plex:
Multiplex:
stretchie_
PostPosted: Wed Jul 26, 2017 3:33 pm Up
Great, thank you guys. Hoping to get it on some axles stands tomorrow as I've got the day off.
Cheers
