Forums › The Car › 206 Problems › Ignition Barrel Sensor |
Posted: Fri Aug 25, 2017 8:22 am |
Has anyone encountered issues with their ignition barrel sensor?
Cheers
Posted: Wed Aug 30, 2017 7:50 pm |
What's up with it?
Someone I knew couldn't turn their engine off when they turned off the ignition and removed the key. Is that anything to do with a sensor? Turned out there was a foreign object lurking in the barrel! 'Fluff' I think Mr RAC said!!
Posted: Thu Aug 31, 2017 9:02 am |
Car randomly cuts out, it doesn't stall, but I lose all mechanical power, the electrics are still on.
If I try to restart (whilst slowly grinding to a halt) with the key in the barrel, it doesn't work.
If I take the key out of the barrel and then reinsert, it starts. I don't even have to turn the key, just reinserting it, starts the car mechanically.
It really is odd.
