Online Now [314]:
Visitors: 313
Today: 109528
Total: 155979048
Forums › The Car › 206 Talk › Hazard light with central locking switch
Forum Index › 206 Talk
RocknRolla_zg
PostPosted: Sun Oct 01, 2017 11:33 am Up
Hi, is it possible to fit and replace regular hazard light switch button with central locking and hazard light. Does it need pp for activation of locking ? Plus is there option for side lights to activate when you open door? Phase 2 model 2004
Thanks Very Happy
I came, I saw, I conquered.
gpvecchi
PostPosted: Sun Oct 01, 2017 4:17 pm Up
Yes, you have to connect the button to the speedo (1 wire), update BSI and enable a couple of functions.
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
RocknRolla_zg
PostPosted: Mon Oct 02, 2017 12:35 pm Up
Thank you for the info vecchi.
gazza82
PostPosted: Mon Oct 02, 2017 1:28 pm Up
Don't think that will operate the side-lights with the doors though ... just the hazards/central locking
PostPosted: Mon Oct 02, 2017 2:09 pm Up
Older BSI software versions used to automatically activate the follow me home headlamp function if the light sensor ( if fitted ) detected it was dark.
Peugeot changed the feature due to complaints in the newer BSI software requiring the driver to operate the headlamp stalk every time they wished to trigger the follow me home headlamps.
Turn the ignition OFF & pull the headlamp stalk towards you ( as to flash the headlamps ) & the dipped beam will come on & stay on for 30 seconds.
