Online Now [427]:
Visitors: 426
Today: 140970
Total: 155233349
Forums › The Car › 206 Problems › ENGINE FUSE BOX WIRE'S BURNED, where they connect to? Won't
Purplemaz_s
PostPosted: Tue Oct 10, 2017 9:18 am Up
Hi
I've been having problems with my Peugeot 206 hdi d turbo 2.0 2003. It cranks over but won't start. Crying or Very sad We had a look in the fuse box next to the battery. The little grey compartment with wires coming out has one connection that's burned. Photos show location and burn. I was hoping someone could tell where that's connects to. Thanks for reading hope you can help. Very Happy cheers
gazza82
PostPosted: Tue Oct 10, 2017 12:50 pm Up
So that looks like Pin 11. What colour is the wire connected to that burnt connection? I can't tell from the pics but think it might be BLUE?
PezHdi
PostPosted: Tue Oct 10, 2017 4:57 pm Up
This happened to me.
I basically got a 2nd hand plug from the scrappy and rewired it.
It takes time and patients but it did the trick.
you will need to clean the Fuseboard and new plug with some electrical contact cleaner and the put some electrical silicone spray.
Hope this helps.
Pez
EXL Pez
PostPosted: Tue Oct 10, 2017 7:48 pm Up
There is a special tool for removing the contacts from the connector plugs - makes the job a lot easier.
The connector pins are also available to buy.
Purplemaz_s
PostPosted: Wed Oct 11, 2017 10:04 am Up
gazza82 it's a thin red wire on the right side third from top.
Purplemaz_s
PostPosted: Wed Oct 11, 2017 10:13 am Up
Pez and MrBSI thanks for advice.
I'v been told it's the fuel injector pump. Mechanic bypassed fuel filter and still wouldn't turn on. Is the burnt wire connected to fuel injector?
PostPosted: Wed Oct 11, 2017 7:09 pm Up
What condition are fuses 3 and 4 like? One of them is for the fuel pump.
I had this problem years ago, the connection between the fuse and the connector was electrically burned. I had to swap the fuse boards but it happened again. I sold the car because of it.
When you turn the key in the ignition can you hear the pump priming. If not thats your problem.
gazza82
PostPosted: Thu Oct 12, 2017 12:50 pm Up
Deleted!
Purplemaz_s
PostPosted: Thu Oct 12, 2017 4:14 pm Up
Burnt connection is in grey plug. The wires Deffo red.
gazza82
PostPosted: Fri Oct 13, 2017 7:47 am Up
My bad .. looking at wrong one! I've deleted the post! There are TWO grey plugs .. the one next to the green one then!
Purplemaz_s
PostPosted: Sat Oct 14, 2017 7:46 pm Up
Yes that's right gazza.
Checked fuses three and four fuse box diagram shows they are for abs and engine management unti.
www.autogenius.info/pe...x-diagram/
Checked fuse 8 and 15 says for fuEl injectors. The wire isn't broken but the prongs are half brown
