Latest: ArtistKS
Overall: 17145
Online Now [293]:
Visitors: 292
Today: 29928
Total: 115929620
Forums › The Car › Solved 206 Problems › 206 H4 To H7 Trouble shooting
Jamerz
PostPosted: Thu Oct 19, 2017 12:54 pm Up
I recently fitted H7 dual bulb headlamps as an upgrade from the H4 Single bulb. I plugged them into the H7 connectors that were thankfully fitted on my 52 plate before the face lift.
However when I put full beam on the dipped beam doesn't stay on, and visibility is poor. I was wondering if there is a fuse or relay that needs putting in or any wires need snipping and connecting to allow for both to come on at full beam?
1.1 206 LX, Tivoli Blue
southwestchap
PostPosted: Thu Oct 19, 2017 2:43 pm Up
in Peugeot planet you need to change the bulb type to twin (or something along those lines)
Had to do it on my 2002 HDi when fitting crystals.
PostPosted: Thu Oct 19, 2017 4:48 pm Up
Or change the light stalk to one from a multiplex car.
PostPosted: Thu Oct 19, 2017 8:24 pm Up
Stalks on multiplex are all the same, just a digital switch that sends a signal to the BSI unit.
BSI unit controls the headlight output.
It just needs BSI configuration set up changing from SINGLE OPTIC to DOUBLE OPTIC with Peugeot Planet / Diagbox.
Jamerz
PostPosted: Fri Oct 20, 2017 4:27 am Up
Lovely thanks for the reply, do you think that this could be done on one of those cheap ebay kits? or should I look for someone local that can do it for me?
PostPosted: Fri Oct 20, 2017 4:49 am Up
But if he's got a preplex car changing the stalk will work. Did on my old car.
PostPosted: Fri Oct 20, 2017 6:35 am Up
Jamerz has a phase 1 multiplexed car so it needs the BSI config tweak to get the lights working correctly.
VorTechS
PostPosted: Fri Oct 20, 2017 6:36 am Up
Staff - Vortechs
That option isn't available on all cars. Don't know if it's just missing for pre-plex or not. It's wasn't available for me anyway.
PostPosted: Fri Oct 20, 2017 7:40 am Up
Pre plex wont have the option as the electrical system is different - pre plex you change the stalk.
I think a lot of people are getting confused between pre plex & multiplexed / phase 1 & phase 2.
VorTechS
PostPosted: Fri Oct 20, 2017 8:43 am Up
Staff - Vortechs
Makes sense. I know there was a relay option touted a long time ago for pre-plex (I looked into it, but never got round to doing it), but I didn't know that pre-plex / multiplex stalks were inter-changable.
PostPosted: Fri Oct 20, 2017 9:23 am Up
There not interchangeable.
Remember phase 1 cars came in both non plexed & multiplexed versions.
Phase 2 where all multiplexed.
gazza82
PostPosted: Fri Oct 20, 2017 9:35 am Up
Not all the same either .. depends whether you have front fogs or not.
PostPosted: Fri Oct 20, 2017 11:07 am Up
I think my car may have been a crossover then. It came with h4 lights but I changed to crystals and changed the stalk
Jamerz
PostPosted: Fri Oct 20, 2017 11:19 am Up
Thank you for telling me this, just trying to figure out how to tweak it, do you think a dealership would do it cheap? Or should I buy a Chinese PP2000 kit?
VorTechS
PostPosted: Fri Oct 20, 2017 11:26 am Up
Staff - Vortechs
There might be someone local to you who'd do it for you.
Where are you located?
