Posted: Thu Oct 19, 2017 12:54 pm |
I recently fitted H7 dual bulb headlamps as an upgrade from the H4 Single bulb. I plugged them into the H7 connectors that were thankfully fitted on my 52 plate before the face lift.
However when I put full beam on the dipped beam doesn't stay on, and visibility is poor. I was wondering if there is a fuse or relay that needs putting in or any wires need snipping and connecting to allow for both to come on at full beam?
Posted: Thu Oct 19, 2017 2:43 pm |
in Peugeot planet you need to change the bulb type to twin (or something along those lines)
Had to do it on my 2002 HDi when fitting crystals.
Posted: Thu Oct 19, 2017 4:48 pm |
Or change the light stalk to one from a multiplex car.
Posted: Thu Oct 19, 2017 8:24 pm |
Steve206 wrote: |
Or change the light stalk to one from a multiplex car. |
Stalks on multiplex are all the same, just a digital switch that sends a signal to the BSI unit.
BSI unit controls the headlight output.
It just needs BSI configuration set up changing from SINGLE OPTIC to DOUBLE OPTIC with Peugeot Planet / Diagbox.
Posted: Fri Oct 20, 2017 4:27 am |
MrBSI wrote: |
Steve206 wrote: |
It just needs BSI configuration set up changing from SINGLE OPTIC to DOUBLE OPTIC with Peugeot Planet / Diagbox. |
Lovely thanks for the reply, do you think that this could be done on one of those cheap ebay kits? or should I look for someone local that can do it for me?
Posted: Fri Oct 20, 2017 4:49 am |
MrBSI wrote: |
Steve206 wrote: |
But if he's got a preplex car changing the stalk will work. Did on my old car.
Posted: Fri Oct 20, 2017 6:35 am |
Jamerz has a phase 1 multiplexed car so it needs the BSI config tweak to get the lights working correctly.
Posted: Fri Oct 20, 2017 6:36 am |
MrBSI wrote: |
Steve206 wrote: |
That option isn't available on all cars. Don't know if it's just missing for pre-plex or not. It's wasn't available for me anyway.
Posted: Fri Oct 20, 2017 7:40 am |
VorTechS wrote: |
MrBSI wrote: |
Steve206 wrote: |
That option isn't available on all cars. Don't know if it's just missing for pre-plex or not. It's wasn't available for me anyway. |
Pre plex wont have the option as the electrical system is different - pre plex you change the stalk.
I think a lot of people are getting confused between pre plex & multiplexed / phase 1 & phase 2.
Posted: Fri Oct 20, 2017 8:43 am |
MrBSI wrote: |
I think a lot of people are getting confused between pre plex & multiplexed / phase 1 & phase 2. |
Makes sense. I know there was a relay option touted a long time ago for pre-plex (I looked into it, but never got round to doing it), but I didn't know that pre-plex / multiplex stalks were inter-changable.
Posted: Fri Oct 20, 2017 9:23 am |
VorTechS wrote: |
but I didn't know that pre-plex / multiplex stalks were inter-changable. |
There not interchangeable.
Remember phase 1 cars came in both non plexed & multiplexed versions.
Phase 2 where all multiplexed.
Posted: Fri Oct 20, 2017 9:35 am |
Not all the same either .. depends whether you have front fogs or not.
Posted: Fri Oct 20, 2017 11:07 am |
I think my car may have been a crossover then. It came with h4 lights but I changed to crystals and changed the stalk
Posted: Fri Oct 20, 2017 11:19 am |
MrBSI wrote: |
Jamerz has a phase 1 multiplexed car so it needs the BSI config tweak to get the lights working correctly. |
Thank you for telling me this, just trying to figure out how to tweak it, do you think a dealership would do it cheap? Or should I buy a Chinese PP2000 kit?
Posted: Fri Oct 20, 2017 11:26 am |
Jamerz wrote: |
MrBSI wrote: |
Thank you for telling me this, just trying to figure out how to tweak it, do you think a dealership would do it cheap? Or should I buy a Chinese PP2000 kit? |
There might be someone local to you who'd do it for you.
Where are you located?
