Latest: evert
Overall: 17112
Online Now [24]:
Visitors: 23
Today: 11381
Total: 93719482
Forums › The Car › 206 Problems › GTi 180 annoying noise
gpvecchi
PostPosted: Thu Jan 18, 2018 8:20 pm Up
Hi everybody! Anyone experienced a rattle noise from the plastic cover of the timing belt? Mine always did it, I actually located the noise and I would like to fix it...
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
PostPosted: Fri Jan 19, 2018 4:25 pm Up
Are all 3 or 4 bolts in properly?
Sim
PostPosted: Fri Jan 19, 2018 4:49 pm Up
In my case those were the exhaust manifold heat shield nuts that'd come undone, rattle at a specific RPM.
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
gpvecchi
PostPosted: Fri Jan 19, 2018 8:33 pm Up
I just changed cambelt, it did it before and after, so I assume yes...
I already fixed manifold heat shield, that's now silent.
The noise I get comes surely around cambelt, in particular with cold engine, around 1800 rpm.
