Latest: SA01
Overall: 17138
Online Now [108]:
Visitors: 107
Today: 14298
Total: 111260844
Forums › The Car › 206 Talk › 206 timing belt help
Bigsteve87
PostPosted: Mon Feb 26, 2018 5:29 pm Up
Hi all . Can someone help trying order at timing belt kit and says there are two different ones to choose from 104 or 108 teeth any ideas how I can find out it's a 1.4 8v x reg thanks
RoweY
PostPosted: Mon Mar 05, 2018 9:52 pm Up
Usually your belt will have the number stamped on saves counting the teeth. Then give your motor factors the number and they should be able to sort you out. I'd personally use a Gates kit just as i have had bad experiences with the cheaper alternatives.
PostPosted: Wed May 30, 2018 10:49 am Up
I can give you the OEM number,if you send me the car VIN,then you can order the aftermarket set according to the OEM number.
