Posted: Sun Mar 11, 2018 2:14 pm |
Hey guys, my car used to only whine in 2nd gear, however its whining/ whirring in all gears now, wondering if it could be a driveshaft issue or the box is dead, sometimes it feels like it bites 3rd gear also.
Posted: Sun Mar 11, 2018 2:28 pm |
What size wheels are fitted?
Anything bigger then 15" on the MA gearbox isn't recommended.
Posted: Sun Mar 11, 2018 2:32 pm |
MrBSI wrote: |
Anything bigger then 15" on the MA gearbox isn't recommended. |
I've Got 14" Vulcan alloys from a 106
Posted: Sun Mar 11, 2018 2:40 pm |
Check the gearbox oil level.
Check the driveshaft support bearing.
Find your local gearbox specialist as a quick test drive by an expert can soon tell you if it's the box or something else in the drivetrain.
Posted: Sun Mar 11, 2018 2:46 pm |
MrBSI wrote: |
Find your local gearbox specialist as a quick test drive by an expert can soon tell you if it's the box or something else in the drivetrain. |
Alright Thankyou, however I've heard there's no way to check the level without draining it all?
Posted: Tue Mar 13, 2018 11:16 pm |
Unscrew the level/top-up cap nut. Keep topping it up with fresh gearbox fluid until it starts to leak out - that's when it's on the level
