Online Now [239]:
Visitors: 237
Members: 1
Today: 57749
Total: 156669892
Forums › The Car › 206 Problems › Flat Battery... Cant lock boot, Disconnected cable?? HELP!
JFraser83
PostPosted: Sun May 13, 2018 1:15 pm Up
Hi all. First post here and I am a complete car novice Crying or Very sad
First of all i went to start my car and there was nothing: no digital read out, no ticking over, no lights etc...so i presume the battery is dead. I will get this jump started/charged, which is no problem...however now i cannot lock the boot without the central locking working?? any way i can do this manually?
next, after investigating why i cannot start my car, i saw a disconnected cable on the passenger side footwell under the glove box.
what is this for and should it be connected? im pretty sure I have not pulled this out at any point and the car has been working fine for years?? (if this is the battery connection, then i guess this answers all my queries!)
any help would be greatly appreciated!
model: 206, 1.1l look 2002
mtempsch
PostPosted: Sun May 13, 2018 4:21 pm Up
Brake switch. With if not mounted so it's depressed by the linkage (on a RHD car) the brake lights will be constantly on (though I believe they would shut off with the car, but not 100% positive)
Silvermetallic 2004 206 RC
JFraser83
PostPosted: Mon May 14, 2018 5:52 am Up
@mtempsch - thanks for this info. Basically this cable connects my brakes to the rear brake light then? (Not sure what you mean by "it's depressed by the linkage")
So this definitly needs to be connected into the left hole in my photo?
Could the disconnection be the reason I have a flat battery?
VorTechS
PostPosted: Mon May 14, 2018 6:40 am Up
Staff - Vortechs
Yes it needs to be in that hole, no it won't be the cause of the flat battery.
The most likely causes of a flat battery are external equipment (incorrectly wired stereo, non-factory fitted alarm etc), or the alternator not topping up the battery when you're using the car.
JFraser83
PostPosted: Mon May 14, 2018 11:36 am Up
great thanks VorTechS, Im going to jump start tonight with it plugged in and see what happens.
It seems to be in too firm to have been accidentally popped out, so im thinking git has maybe been disconnected intentionally by a mechanic. Could there be a reason?
Sim
PostPosted: Mon May 14, 2018 11:39 am Up
Any lanky passenger would have kicked it out of position over time Smile
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
JFraser83
PostPosted: Mon May 14, 2018 11:45 am Up
i make sure i only ever drive short passengers! Wink
gazza82
PostPosted: Mon May 14, 2018 2:46 pm Up
It would if the brake lights have been on .. a lot of brake switches work but pushing away from the switch so if it was hanging loose, it would be in circuit and the brake light bulbs on ..
JFraser83
PostPosted: Mon May 14, 2018 3:00 pm Up
This makes sense to me.... Thanks one and all!
PostPosted: Tue May 15, 2018 5:35 am Up
206 brake lights only work when the ignition is switched ON.
It's Japanese stuff where brake lights work without the ignition
JFraser83
PostPosted: Tue May 15, 2018 6:43 am Up
ah. ok. Any reason a mechanic would have disconnected this? (to combat faulty lights/wiring etc)
VorTechS
PostPosted: Tue May 15, 2018 7:10 am Up
Staff - Vortechs
In all honesty, it could have just been knocked whilst someone was working behind the centre console, removing the glovebox (for access to things like the coolant pipe that site inside the cabin) and it is surprisingly easy for someone to kick it off. It really doesn't take much to knock it out of its hole.
