Online Now [634]:
Visitors: 633
Today: 130223
Total: 154513489
Forums › The Car › 206 Problems › If BSI is changed does it stop the remote key working?
SamanthasHubby
PostPosted: Sat May 26, 2018 6:36 pm Up
I have just bought a 206 and the remote locking and central locking doesn’t work - put new batteries in the keys and tried a BSI reset but nothing seems to work.
If the previous owner has changed the BSI would this cause the locking to stop working?
gazza82
PostPosted: Sun May 27, 2018 7:10 pm Up
Yes.
Search on here for instructions to try and rematch your keys to car ... otherwise you need access to pp2000
PostPosted: Wed May 30, 2018 10:17 am Up
Well if the previous owner told you that he replaced the BSI,then yes that will make the key fob not working and you need PP2000 and the PIN code to make the connect to the car,but if it still got the old BSI then you have a problem with the key fob itself.
