Latest: KevinRC
Overall: 17137
Online Now [140]:
Visitors: 139
Today: 86842
Total: 111121430
Forums › The Car › 206 Problems › Later white face dials instrument panel.
purrjoe
PostPosted: Sun Jul 22, 2018 8:10 pm Up
Is the later type instrument panel, as per title, a straight forward direct replacement for the original black faced version?
I have a 2003 1.4HDI hatch and am looking at a 2006 speedo from a similar model.
Also, will the original mileage on my 206 show up on the replacement speedo?
Many thanks in advance of any advice. Smile
PostPosted: Mon Jul 23, 2018 3:24 am Up
You need a replacement cluster with a LOWER mileage then your car currently displays else you will trigger the anti clocking protection.
You also idealy need a cluster from a diesel due to lower red line on rev counter.
If the replacement cluster has the oil temp gauge then it won't work until the temp sensor is fitted & the BSI configuration is adjusted.
Other then those points, simple plug & play.
Don't worry About the headlamps coming on when cluster unplugged, just the cars safety logic.
purrjoe
PostPosted: Mon Jul 23, 2018 9:26 am Up
Many thanks for your informative reply MrBSI
As my car has covered only 40K miles I think the chances of finding a later style speedo head with less than that maybe a challenge !
Again, many thanks though. Smile
gazza82
PostPosted: Mon Jul 23, 2018 10:40 am Up
I'm not even sure they did a white-faced dial set on the 1.4Hdi .. did they?
purrjoe
PostPosted: Mon Jul 23, 2018 5:36 pm Up
Well it seems that they did.
www.ebay.co.uk/itm/Ins...1438.l2649
Unless, of course, these are incorrectly described ! Smile
VorTechS
PostPosted: Tue Jul 24, 2018 9:04 am Up
Staff - Vortechs
They may well have just been fitted retrospectively rather than out of the factory though Wink
