Online Now [299]:
Visitors: 298
Today: 138507
Total: 154693900
Forums › The Car › 206 Problems › Will not start crank sensor ??
dlovett
PostPosted: Mon Jul 23, 2018 9:02 pm Up
Hello, my 2003 206 1.4hdi SW, broke down on holiday and after a 22hour recovery from Devon, the car is back home. The day before it kangarooed a couple of times and the next day the engine just died. The RAC came out and found two error codes, one was about the clutch pedal switch DTC: P0704,Clutch Switch Input Circuit Malfunction and the other was that the crankshaft Position sensor was reporting a fault DTC: P0337,Crankshaft Position Sensor A Circuit Low Input. Can anybody tell me where on the engine the Crankshaft Position Sensor is so I can check the contacts on it and the plug and if not replace the sensor. Ideally a picture if possible.
Many thanks
D
dlovett
PostPosted: Wed Jul 25, 2018 9:29 pm Up
After jacking up the car and removing the driver's front wheel and the wheel arch plastic it was very easy to get to. Cleaned all round the plug area with degreaser, un plugged it and clean both the plug and sensor socket with electrical cleaner and now the car starts and runs fine again. here are two pictures showing it incase it helps anybody else.
gazza82
PostPosted: Thu Jul 26, 2018 11:44 am Up
Glad to hear you sorted it .. although no sign of any pics!
dlovett
PostPosted: Sat Jul 28, 2018 6:44 pm Up
Should be there now, they didn't upload the first time.
gazza82
PostPosted: Sat Jul 28, 2018 9:18 pm Up
They are. And yes that's the little wotsit I had to change ... crank pulley and lower part of cam cover had to come off as did aux belt.
