Forums › The Car › 206 Problems › Y Reg Climate Control Issue |
Posted: Tue Aug 07, 2018 6:19 pm |
Hello,
I am new to this and am hoping to find someone with good knowledge of 206’s to help diagnose a problem. My Y-reg 206 has the digital temperature controls but also has a mind of its own. No matter what temperature you select on the heater/blower it will do its own thing. Also, if you manually select fan speeds etc again it will choose to do its own thing.
Does anyone have any suggestions as to what may cause this and, more importantly, how it can be fixed?
Thanks in advance.
Posted: Tue Aug 07, 2018 7:37 pm |
Probably a new fan needed.
