Can anyone explain to me how to remove the petrol cap locking mechanism from the exterior painted moulding?
Obviously I would like to re-use the key and mechanism that is original to the car. I want to fit a sports type moulding with the dummy allen-head bolts, but am unable to remove the key from the lock once the assembly is removed from the fuel neck so stopping the removal of the mechanism.
I just cannot work out how to do it.
Many thanks if you can advise
VorTechS
Posted: Wed Sep 26, 2018 10:07 am
If you look at the reverse side of the mechanism you'll see there's a little latch that you can 'push in'.
Press that in, whilst turning the key and you'll be able to remove it.
purrjoe
Posted: Wed Sep 26, 2018 11:43 am
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
