Online Now [383]:
Visitors: 381
Members: 1
Today: 40112
Total: 152883401
Forums › The Car › 206 Talk › Siphoning petrol
Siphoning petrol
Forum Index › 206 Talk
RandyMcShagSwindon
PostPosted: Sat Apr 13, 2013 4:25 am Up
hey there. Sad times, looks like im gunna be scrapping my 206. but am replacing it with a 306. The thing is, i still got half a tank of fuel in the 206. A family member said some cars are fitted with a device that stops you being able to siphon the petrol out of the tank, is anything like this fitted to a 206?
\'99 Pug 206 1.6xs
PostPosted: Sat Apr 13, 2013 4:41 am Up
Yes.
RandyMcShagSwindon
PostPosted: Sat Apr 13, 2013 4:44 am Up
damn! was hoping that wasnt gunna be the reply! Dont suppose there is anyway round it either is there?
\'99 Pug 206 1.6xs
PostPosted: Sat Apr 13, 2013 4:47 am Up
Why are you scraping it?
Has it crashed?
Otherwise you could just keep driving it a bit so you get to use the petrol.
RandyMcShagSwindon
PostPosted: Sat Apr 13, 2013 4:55 am Up
its leaking oil like there's no tomorrow. Has plenty of other issues too, and just dont have the cash to get it fixed! Been offered a 60k 306 xsi 2.0 and all i have to pay is to put tax on it, so jumped at it. may well list the car as spares or repairs yet. still got 5months tax and mot til end of june (i thinks).
\'99 Pug 206 1.6xs
iainlovatt
You need to remove the petrol tank and then poor the petrol into a container and then put it in another car. It's a 2 man job and u get covered in petrol . Smile
(My Garage)
PostPosted: Sat Apr 13, 2013 5:20 am Up
Just connect the pump direct to a battery and instead of the pipe going to the engine, you put it into a jerry can or even easier is to access the tank from on top and stick your pipe in there to syphon it out.
PostPosted: Sat Apr 13, 2013 6:01 am Up
Take the back seats out, and do it from the above, by remove the pump, as macca said.
PostPosted: Sun Apr 14, 2013 5:39 am Up
This
Makes easy work of it
thebanksman
PostPosted: Sat Nov 10, 2018 11:55 am Up
Hi. I have damaged my 206 HDi and it's a write off Sad and typically I'd only just put a full tank of diesel in. Please can someone advise how to syphon it? I've taken the back seat up and the attached picture is what I am faced with but I don't know what to do.
If anyone can advise I'd be very grateful including how things are supposed to undo if need be (I don't want to force / break anything with fuel knocking around).
Thanks,
John
PostPosted: Sat Nov 10, 2018 12:06 pm Up
Undo that big black plastic ring & lift the sender unit out.
It will unscrew but it will be tight.
The pipes will be clipped on, normally press a clip in to release the pipe, again these will be tight.
thebanksman
PostPosted: Sat Nov 10, 2018 12:42 pm Up
Thanks. Sorry to be thick but when it's unscrewed what do I do? Does that expose the inside of the tank to put a pipe in to?
PostPosted: Sat Nov 10, 2018 2:16 pm Up
The white plastic piece will lift out exposing the inside of the fuel tank.
thebanksman
PostPosted: Sun Nov 11, 2018 10:17 am Up
Sorry - forgot to say thanks. I've not managed to get round to doing it yet, but your advice is most appreciated.
PostPosted: Wed Nov 14, 2018 7:41 pm Up
Use a flathead screwdriver and a hammer to undo the ring. Ive done it before and its the only thing that worked!!
