Online Now [1044]:
Visitors: 1043
Today: 137950
Total: 151269215
Forums › The Car › 206 Problems › 206 gti 2000 reg running on 2 cylinders
usher
PostPosted: Fri Feb 22, 2019 7:27 pm Up
Can anyone shed light on this I have a 206 gti 2000 reg that I'm turning into a track car. I serviced it the other month everything was running sweet no issues untill I turned it off the power steering pipe burst no drama but the next day when I started it up it ran horribly on cylinders 2 and 3. I've changed the coil pack with no luck. I've even changed the interior loom with no luck the obd isn't showing any fault codes. I've checked all wires and connectors with nothing standing out of the ordinary
Does anyone have anything to try. The plugs in 1 and 4 are wet so fuel is getting to the cylinders. I've tested the plugs outside of the engine and 1 and 4 are not sparkng as expected oh they have also been replaced there isn't much left unchanged lol
Thanks in advance
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
PezHdi
PostPosted: Sat Feb 23, 2019 8:54 am Up
Leads from coil pack to plugs?
EXL Pez
usher
PostPosted: Sat Feb 23, 2019 12:55 pm Up
Coil pack has been changed and wires look fine as do connections to ecu plugs etc
project thread WIP
garage
FAQ
206 gti firedance
usher
PostPosted: Sat Feb 23, 2019 4:29 pm Up
Gone over checked all contacts and checked all wires for brakes and corrosion. Used contact spray and tested sparks again. I even swapped the 2 wires that control the spark and no luck was a long shot. Gonna change the ecu now anything to look for when getting another ecu
project thread WIP
garage
FAQ
206 gti firedance
