Online Now [243]:
Visitors: 243
Today: 100042
Total: 155703115
Forums › The Car › Request a how-to › Clutch cable replacement on pug 206 1.4 8v (2000 Reg)
Bluepug1
PostPosted: Sat Mar 16, 2019 3:41 pm Reply with quote Up
Hi all, When I try take off the clutch cable it stuck I cannot find clip to release the cable. I watched Youtube in french pug 206 has a clip on cable under pedal to release clutch cable but that is on left hand not on right-hand car that i unable to find.
I have cut off the cable only left is that metal tube with plastic and rubber that i have torn off on 1st pic how Can I remove it?
Sorry I am not good writing English.
This is cable release clip
Where is it? xD
Sim
PostPosted: Sat Mar 16, 2019 7:42 pm Reply with quote Up
It's at the very top of the pedal, see Haynes picture 3.3 should hopefully clear things up:
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
Bluepug1
PostPosted: Sun Mar 17, 2019 2:35 pm Reply with quote Up
That exact what I did, cable still won't pull off from bulkhead and i cut off old cable only left is that cable end plasic thing that need to be taken off and fit new cable.
I cut off old cable only left is this picture how can i rid this thing off
Sim
PostPosted: Sat Mar 23, 2019 10:39 am Reply with quote Up
Your new clutch cable will come with the plastic bracket and the rubber grommet, so this should just come off easily, unless something is stuck on the other side.
By the way, many forum posts warn to carefully follow installation steps of the new cable if it's your first time replacing it www.206info.co.uk/Foru...tml#641631
EV (roadtripper)
GTC VXR (sold)
  Quick Reply
Username:
Message:
Quote the last message
