Latest: sparrowdclxvi
Overall: 17139
Online Now [167]:
Visitors: 166
Today: 40339
Total: 113488331
Forums › The Car › 206 Problems › ODB connection issue / SKID warning lamp
bigwul
PostPosted: Thu Sep 26, 2019 11:50 am Up
Just put my trusty old 98 plate 206 1.6 petrol back on the road - to give to my daughter - done loads new parts and all good.
The one fly in the ointment seems to be the SKID light - that when my local MOT station say it - rightly failed the car.
Problem they have - he says cannot access the OBD port.....
Just wondered if this is common.?
I do not know what system he uses - but says he has no issues with other Pug's....
Any thoughts?
Sim
PostPosted: Thu Sep 26, 2019 12:09 pm Up
Hi,
By SKID you probably mean ABS warning light.
Yes it would be good to connect OBD reader (just near the interior fusebox) to see which ABS sensor is at fault.
If the scanner they have doesn't work, maybe for a simple sanity-check they or someone else could try to plug-in the simplest fault reader, just to read off the codes.
You could get them cheap from ebay, the Bluetooth ones, that talk to your android/iphone via the Torque app.
The best would of course be to find someone with Peugeot Planet and check again. I reckon going to official dealership is off the table?
PS: And by 98 plate you meant the R or S plate? Just trying to see if you are in UK and if someone nearby with a PP2000 could help you out:)
Daily Red GTi 180, year 2004 (VorTechS' sEXy Beast (being) remasteRed)
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
bigwul
PostPosted: Thu Sep 26, 2019 12:31 pm Up
It's an S plate - and it's not the ABS warning light.....it's the ESP warning light - the little 'skid' symbol.....
I am located in Hawick - Scorttish Borders.
bigwul
PostPosted: Thu Sep 26, 2019 12:37 pm Up
The MOT station reckons he cannot communicate at all - and he has not got this issue with Pug usually.
VorTechS
PostPosted: Thu Sep 26, 2019 12:42 pm Up
Staff - Vortechs
Is it only the dashboard light, or is there a visible warning on the MFD when the car is in use?
bigwul
PostPosted: Thu Sep 26, 2019 1:03 pm Up
It's the dash light......not noticed any thing else.
bigwul
PostPosted: Thu Sep 26, 2019 1:04 pm Up
ah - but then again the lights for the MFD are blown - forgot about that....so cannot see anything......
gazza82
PostPosted: Thu Sep 26, 2019 1:42 pm Up
The obd port is powered by a fuse (engine bay). We had the same no eml light issue. A 98 will also need a psa compatible reader ... they were very non-standard back then.
bigwul
PostPosted: Thu Sep 26, 2019 6:13 pm Up
I will check for the fuse - garage guy reckons first Pug he cannot speak to....
Thanks for reply
gazza82
PostPosted: Thu Sep 26, 2019 9:09 pm Up
Depends what years the others are .. later models are more standard .. but the BSI is out of bounds unless you use PP2000. Cables can be different too ...
Fuses listed here ... 206info.co.uk/Forums/v...7.html#top
F14 .. probably a 5amp
PostPosted: Sun Sep 29, 2019 7:07 am Up
A 98 year 206 isn't going to have ESP fitted.
What's the VIN of the 206?
It may have ABS fitted - the warning light will either say ABS or it will have a picture of the car skidding, the 206 has used both types of these warning lights over the years depending on spec.
bigwul
PostPosted: Sun Sep 29, 2019 10:31 am Up
It has the ABS light and the ESP light
The ABS light illuminates then goes out - the ESP is constant.
bigwul
PostPosted: Sun Sep 29, 2019 10:53 am Up
Interstingly - just replaced F14 - it was blown - blew immediately again - any ideas.?
bigwul
PostPosted: Sun Sep 29, 2019 10:57 am Up
It has type 3 fusebox according to this link......
fusesdiagram.com/peuge...t-206.html
bigwul
PostPosted: Sun Sep 29, 2019 11:46 am Up
Yup - you were right - but you knew that!!
The other light is the Airbag light...!
Please accept my apologies..........
