Online Now [273]:
Visitors: 272
Today: 146428
Total: 154700759
Forums › The Car › 206 Problems › 2.0 HDI Dipstick Tube Removal
BikerDave
PostPosted: Tue Oct 01, 2019 10:48 am Up
Hi Guys, I am trying to remove the dipstick tube on my 03 206 2.0 HDI to remove the broken part of the dipstick. The bolt/s fastening it to the engine (not sure if there are 1 or 2) are completely inaccessible.
Has anyone overcome this is so how did you do it?
Thanks in advance
gazza82
PostPosted: Tue Oct 01, 2019 2:19 pm Up
I took the manifold off!! ... but I was replacing the two core plugs in the head of my 1.4 hdi ..
I don't think you can remove that tube easily .. can you push the remains down into the sump? It's unlikely to do any damage in the bottom ...
PostPosted: Tue Oct 01, 2019 4:30 pm Up
This is what I have done in the past with a TU3 lump.
The mesh on the end of the oil pick up pipe will stop it being sucked back in to the oil pump.
If your really lucky & get the engine oil hot it may even come out next time the oil is drained.
gazza82
PostPosted: Tue Oct 01, 2019 6:13 pm Up
My old Alfa 75 had the ends of two dipsticks in the sump!!
BikerDave
PostPosted: Fri Oct 04, 2019 4:43 pm Up
Thanks gents. It seems fairly well lodge and wont go down with the dipstick. I might try and ram it down with a welding rod or similar.
