Latest: evert
Overall: 17112
Online Now [35]:
Visitors: 35
Today: 2973
Total: 93725172
Forums › The Car › 206 Problems › 206 1.4i Sloppy Gear Lever
clicon357
PostPosted: Sun Feb 09, 2020 11:03 am Up
So far down the cash rabbit hole with this old 206 I might as well carry on!
The gear lever on this 1.4i 206 feels "old car" sloppy. Getting into reverse sometimes takes a couple of attempts. Clutch and driveshafts are new. Gearbox oil is new and topped up.
Hoping new levers like this will fix things:
www.ebay.co.uk/i/223371539539?
Any thoughts or is there maybe a worn nylon bush under the gaiter that wears.
Cheers.
..........I can\'t help it I just like French cars!
PostPosted: Sun Feb 09, 2020 11:54 am Up
Gear change on this old MA gearbox was never the best even when new.
As for reverse - return the gear lever to neutral, fully release the clutch pedal, wait a couple of seconds then try again.
It's a characteristic of the mid 1980s MA gearbox design.
ekjdm14
PostPosted: Sun Feb 09, 2020 11:16 pm Up
The finding reverse thing, yes "they all do that, sir" Wink However, one thing I've found (only on 1.4i strangely, and on maybe 3 or 4 now!) is the lever felt really sloppy, like BL A-series with the selector dropping out sloppy... This has been, on these cars at least, no more than the nut/bolt holding the selector to the gear lever under the car. Check it with the car cold as it's close to the exhaust but this might sort things...
How's the whine thing coming on?
+'99 306 2.0SE cabriolet
+'97 306 1.9LXDT
French Car Forums
clicon357
PostPosted: Mon Feb 10, 2020 3:05 pm Up
Thanks for that.
Not been able to use the ramp as the owners wife seriously ill and I'd feel a bit guilty asking at the mo. Bearing sitting here waiting. I've in fact got the one you said AND another that says it's for my compressor. So a 50 and a 55mm I think. Both PFS. Was worth the extra tenner so I don't have to do it twice! I'll let you know as soon as it's done.
