Posted: Thu Feb 20, 2020 9:23 pm |
my side lights will not come on by them self but come on when head lights are turned on? its a 2002 206cc
Posted: Fri Feb 21, 2020 9:31 am |
Might be the lighting switch ..
Posted: Fri Feb 21, 2020 10:06 am |
just had a look and it looks like someone as wired the side lights to the head lights so come on at the same time the funny thing ic the dash lights come on in first notch
Posted: Fri Feb 21, 2020 3:25 pm |
Dash light is controlled by the column switch not the wiring to the sidelights.
And pretty sure that bodge illegal in UK ..
Posted: Fri Feb 21, 2020 5:56 pm |
failed mot but tester tolled me if i hard wire them to come on from say the ignition key switch might get away with it just means will be on all the time the keys turned on or running
Posted: Mon Feb 24, 2020 3:43 pm |
Wonder why they have bodged it like that? Can't really see the point?
Posted: Mon Feb 24, 2020 5:51 pm |
i suppose like me i only put the head lights when out at night so never looked like it was a problem with all the lights working the person that had it before me must have lost all the side and back lights and with the way the electrics on these cars work it was the easy way out and trying to find a wiring diagram for it that match this car is not easy i am old school 60s and 70s (battery wire switch wire bulb)its not a problem now so will sort it properly when the weather gets better
Posted: Mon Feb 24, 2020 6:04 pm |
I tried to replace the rear brake light with an LED unit on the daughter's old CC and everytime I shut the bonnet the light stopped working .. the cable was a tad too short so it pulled and unplugged itself from the loom .. so we refitted the old one with most of the bulbs dead .. still passed the mot oddly!!
Which reminds me .. must sell that CC LED rear brake light .. it's gathering dust in the garage ..
Posted: Mon Feb 24, 2020 7:05 pm |
yes they are funny little cars but this one only cost £180 with 60000 on the clock apart from the light problem its was snip and the body work and under neath is spot on so even it all goes tits up will still get my money back on it any way thanks for try to help
