Posted: Mon Aug 24, 2020 5:46 pm |
I seem to have a weird electrical issue. My starter motor was dead so replaced it. Engine turns over now but wont fire. I tried a BSI reset but every time I turn the sidelights on through the window it does not 'bong' instead something weird happens like the rear wiper going or some servos/motors can be heard behind the dash or the doors click, alarm primes. any ideas what the hell is going on?
| GTi 180 - Scorpion Exhaust | |
Posted: Tue Aug 25, 2020 1:44 pm |
Hi, Needs a scan with planet, suspecting BSI-ECU comms/immobiliser.
Had such weirdness on 1.4 HDi, sometimes also front wipers activate.
To check your immo status: do you hear bleep with the key in ignition when opening driver's door?
Do wipers work in ignition position (probably not, as been hampered by eco mode by now)?
Posted: Wed Aug 26, 2020 7:46 pm |
Hi. Thanks. Yes I get the bleep bleep bleep when key in ignition and door open. But yeah nothing works because of eco mode. Because the car has been parked facing down a steep incline it looks like rain water has leaked over the engine bay seal onto the ecu connectors.
Posted: Mon Sep 07, 2020 9:00 pm |
Check with Peugeot Planet for which fault is causing the non-start. I'd give them a clear too, fingers crossed your ECU has been resilient enough against water ingress!
Posted: Tue Sep 08, 2020 5:23 pm |
Thanks. I don’t have peugeot planet, I just have an ELM327 which I’ve scanned with but found no fault codes.
