Online Now [360]:
Visitors: 358
Members: 1
Today: 47919
Total: 157712606
Forums › The Car › 206 Problems › 206 pulls left/right when braking/accelerating
Klunk
PostPosted: Tue Mar 21, 2023 11:49 am Up
Hi - I’ve just bought a 1.4 HDI and it’s a great wee car and I’ve fallen in love with the 206. Only problem is a significant pull to the left or right depending on whether I’m braking or accelerating. This makes it a bit twitchy in corners and spoils what is otherwise great handling. I think the car may have had a wishbone replaced for its last MOT, and yet my first thought was that this problem feels like a suspension bush problem. Anyone had a similar issue?
2v50
PostPosted: Tue Mar 28, 2023 11:15 pm Up
I need to confirm my issue with this actually went away after changing the wishbones. I've been jumping from car to car too often and can't remember if it did or not now! My 206 is a 1.6 16v CC, I'll try and get back to you on this tomorrow as i need to put petrol in ... excuse to blast it down the bypass.- I remember having this happening on the motorway and it drove me nuts.
2v50
PostPosted: Thu Mar 30, 2023 8:45 pm Up
Update - No pull at speeds upto 30mph. I changed both wishbones, track rod ends and drop links - full kit from fleabay. I expect you just need a new wishbone - the bolts can be a bit of a pig, but it's not a difficult job with an impact and the right spanner. Ball joint pinch bolt threads like to get damaged - I got mine from a local motor factor for around a fiver!
intermilan206
PostPosted: Tue Jul 18, 2023 8:14 am Up
Usually, it's the wishbone / lower arm bush.
206 1.6L 16V XT - RIP
206 GTi 138++
Koni Sport dampers, H&R springs, GTi180/RC rear axle and front ARB. Sparco strut bar, Yokohama AD08R tyres, Raceland 4-1 manifold, Remus backbox, Magnaflow sport cat, Catcams Fast Road cams, Unichip Q piggyback ECU, Pipercross VIS kit, Vibra Technics mount kit, 283mm Brembo Max front discs and rear discs, Ferodo DS2500 front & rear brake pads, Goodridge brake hoses, 307 23.8mm master cylinder, brake servo and calipers; Quaife LSD, AST adjustable top mounts and 206 WRC rear spoiler (just can't resist it).
Postpone / KIV / Coming soon: Mocal oil cooler kit.
Removed: Combrake top mounts.
