Online Now [64]:
Visitors: 63
Today: 25938
Total: 116677747
Forums › The Car › 206 Talk › VIN decoding
VIN decoding
Toisich
PostPosted: Thu Oct 12, 2023 10:22 am Up
Hi. I don't know if anyone is still doing specs from VINs, but if anyone is, I'd be most grateful if they could please do mine.
VIN is VF32AKFUF43658431
Thanks in advance
Chris
Sim
PostPosted: Sat Oct 14, 2023 7:51 am Up
Here you are:
Code::
Vehicle characteristics
Vehicle family                               206
AS/RP N°                                     09876 83 1 0345
Warranty Start Date                          05/04/2004
Engine serial number                         10 FE01 0000297
BER                                          e2*2001/116*0291*00
General information
PRODUCT TYPE                                 PASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPE             PEUGEOT
VEHICLE FAMILY                               206
SILHOUETTE                                   5 DOOR SALOON
TRIM LEVEL                                   LEVEL XT PREMIUM
ENGINE                                       INJECTION ET3J4
TRANSMISSION                                 BVM5
PAINT TYPE                                   METALLIC PAINTWORK
BODY COLOUR                                  ETS - ASH GREY PAINT
INTERIOR TRIM TYPE                           VELOUR ENJOY F791 + MISTECO F685 "RN"
UPHOLSTERY COLOUR                            "FS"
GEARBOX (CHARACTERISTICS)                    BVM MA5 / N
ENGINE (TYPE)                                ENGINE TYPE ET
OTHER BADGE                                  WITHOUT FULLER BADGE
OTHER BADGE, " MISC. "                       WITHOUT FULLER BADGE
BADGE                                        WITHOUT BADGE
STEERING                                     UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE                            TACHO TORQUE 19X17
Fuel supply-Engine
FUEL FILLER CAP                              FUEL CAP WITHOUT LOCK
DIESEL FILTER WATER DETECTOR                 WITHOUT DIESEL FILTER WATER DETECTOR
CYLINDER BLOCK (MATERIAL)                    CRANKCASE ALUMINIUM
FUEL                                         UNLEADED PETROL 95 QUALITY A/B/E/E+
EMISSIONS STANDARD (ENGINE)                  EURO 4 ENGINE EMISSION CONTROL
PRE-FILTER                                   ASSEMBLY WITHOUT PRE-FILTER
CATALYTIC CONVERTER                          3-COMPONENT RHODIUM+PLATINUM FILTER CATALYSER
OIL COOLER                                   WITHOUT OIL-WATER DISTR CHAMB
OPTIMISATION OF VEHICLE’S CONSUMPTION        WITHOUT FUEL CONSUMPTION OPTIMISATION
COOLING MOTOR                                RADIATOR TH : 18-21 DM2 PAS 1 ALUMINIUM MECHANICAL
CRANKCASE GAS CIRCUIT HEATING                W/O HEATER CASING GAS CIRCUIT
FUEL SUPPLY CUTOFF                           FUEL FEED CUT-OFF
RHEOSTAT                                     RHEOSTAT
EOBD SELF-DIAGNOSIS SYSTEM                   "EOBD" AUTO-DIAGNOSTIC WITH ACCELEROMETER
DEVICE (ANTIPOLLUTION)                       WITHOUT ANTI-POLLUTION DEVICE
VEHICLE TECHNICAL DEPOLLUTION                EURO 3 L4 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTER                              WITHOUT PARTICLE FILTER
FAN                                          1 FAN - 2 SPEEDS 250W 70WAERO
FUEL VAPOUR RETRIEVAL                        CONTROLLED PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT                 MOUNTING MAGNETI MARELLI
TANK FILTER                                  RESERVOIR FILTER INTERIOR
THROTTLE HOUSING (ENGINE INLET AIR CIRCUIT)  MOTORISED THROTTLE BODY (ENG AIR INTAKE)
STOP AND START                               WITHOUT STOP AND START
Gearbox Transmission
TRANSMISSION                                 BVM5
FINAL DRIVE RATIO                            REAR AXLE HYPOID GEARSET 16 X 65
WHEEL STYLE                                  14 INCH STEEL WHEEL
GEARBOX SAFETY LOCK                          W/O G/BOX SECURITY LOCKING
GEARBOX TYPE (TYPE APPROVAL)                 GEARBOX MA/5 N TYPE
DIFFERENTIAL (GEARBOX)                       DIFFERENTIAL 68
TYRE (SIZE, TYPE)                            175/65 R14 82T NON REINFORCED TYRE
WHEELS FITTED                                5,5" RIM ROAD WHEELS
WHEEL (TYPE)                                 STEEL WHEELS
GEARBOX TYPE                                 MA
Suspension-Steering-Brakes
ABS                                          WITH ABS BRAKES
REAR ANTI-ROLL BAR                           ANTI-ROLL BAR DIAM 19
FRONT ANTI-ROLL BAR                          FRONT ANTI-ROLL BAR DIAM 20
SERVICE BRAKE                                ELECTRONIC BRAKEFORCE DISTRIBUTION
BRAKE TYPE                                   VENTILATED FRONT DISCS/REAR DRUMS
SUSPENSION                                   NORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM             WITHOUT ELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANT                     ABS TEVES MK70
PEDAL BRACKET (TYPE)                         PEDAL STANDARD
Body fittings
HORNS                                        HORN STANDARD
AERIAL                                       SHORT ROOF AERIAL
FINISHER (SELF-ADHESIVE)                     MATT BLACK REAR SURROUND TRIM
SIDE MOULDINGS (TYPE)                        LATERAL PROTECTOR MASS TINTED
WHEEL EMBELLISHER (STYLE)                    CUBA STYLE 8 HOLES 14 INCHES
ADDITIONAL SHIELD (UNDER ENGINE)             W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION          EXT MIRROR MANUAL-FOLD BACK
EXHAUST TAILPIPE TRIM                        W/O EXHAUST OUTLET EMBELLISHER
ENGINE BAY SOUNDPROOFING                     BULKHEAD SOUNDPROOFING
WINDSCREEN WIPER                             FRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPER                            REAR SCREEN WIPER
HEADLAMP WIPER                               W/O HEADLAMP WIPER
FRONT PANEL BLANK                            WITHOUT FRONT BUMPER PLUG
ROOF GLASS                                   WITHOUT ROOF WINDOW
BUMPER                                       FR STANDARD CC + CHROME TRIM - RR SPORT CC
MUDFLAP                                      REAR WHEEL FRONT MUDFLAP
LUGGAGE RACK                                 MOUNTING WITHOUT ROOF BARS
FRONT FOGLAMP                                FRONT FOG LIGHTS
SPECIAL HEADLAMP (DOUBLE OPTIC)              DOUBLE OPTIC LAMPS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE)      DRIVER’S DOOR MIRROR ELECTRIC CONTROL
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE)   PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL
SPARE WHEEL                                  EMERGENCY WHEEL
EXTERIOR ACCESSORIES                         BODY COLOURED EXT HANDLES + EXT MIRROR
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS)   EXT MIRROR ASPHERICAL GLASS
SUN ROOF                                     FIXED ROOF
BUMPER TRIM                                  DYED BUMPER STRIP
REAR WINDOW (TYPE)                           REAR GLASS HEATED
GLASS (APPEARANCE)                           TINTED
REAR QUARTER WINDOW (TYPE)                   WITHOUT REAR QUARTER GLASS
WINDOW (TYPE)                                ATHERMAL WINDSCREEN
Interior fittings
ANTI-THEFT ALARM                             WITHOUT THEFT PROTECTION ALARM
CIGAR LIGHTER                                FRONT CIGAR-LIGHTER
REAR HEAD RESTRAINT                          REAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINT                         JOINTED FRONT HEADREST
REAR SEAT                                    SEPARATE FOLD BACK BENCH SEAT
LUGGAGE COVER                                WITHOUT LUGGAGE COVER
REAR SEATBELT                                REAR 3-POINT 3 INERTIA REEL SEAT BELT
FRONT SEATBELT                               PYROTECHNIC SEAT BELT WITHOUT ALARM
CLIMATE (AMBIENT TEMP)                       TEMPERATE COUNTRIES
AIR CONDITIONING                             HEATER MATRIX WITH REAR HEATING
SPEED GRADUATIONS                            SPEED GRADUATION IN MPH
GRAB HANDLES                                 PASS FR HANDLE + REAR + HOOK
TACHOMETER                                   REV COUNTER WITH NEEDLE
RADIO EQUIPMENT                              FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
CONSOLE                                      CONSOLE WITH REAR HEATING
DRIVING POSITION                             RIGHT HAND DRIVE
REMOTE CONTROL                               REMOTE CONTROL ASSEMBLY
ADDITIONAL HEATING                           WITHOUT ADDITIONNAL HEATING
LOAD SPACE LIGHTING                          GLOVE-BOX LIGHTING
BOOT AND LOAD SPACE LIGHTING                 AUTO BOOT LIGHT OR LOAD VOL SWITCH
DASHBOARD EQUIPMENT                          SHINY FASCIA + GREY BUTTON
MISC. INT. LAMPS                             MAP READING LAMP
INSTRUMENT PANEL (CHARACTERISTICS)           GRADUATION 220 KM/H OR 135 M/H BLACK LAND CL CHROM
TACHOMETER (SIGNAL CONNECTION)               REV COUNTER CALC
CHILD SEAT ANCHORING POINTS                  WITHOUT CHILD SEAT MOUNTING
LOUDSPEAKER                                  4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
RADIO CONTROLS                               REMOTE RADIO CONTROL WITHOUT CD FUNCTION
FRONT PASSENGER SEAT HEIGHT CONTROL          WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT ADJUSTMENT                       DRIVERS FIXED LATERAL BEARING
FRONT PASSENGER SEAT ADJUSTMENT              PASSENG FIXED LATERAL BEARING
DRIVER’S SEAT FOLDING                        W/O FOLDING DRIV FRONT SEATING
FRONT PASSENGER SEAT FOLDING                 W/O FOLDING PASS FRONT SEATING
EXTERIOR TEMP. INDICATOR                     EXT TEMP INDICATOR
COMPACT DISC                                 MOUNTING COMPACT DISC
STOWAGE BIN                                  WITHOUT SETTING BOX
SATELLITE NAVIGATION SYSTEM                  WITHOUT NAVIGATION SYSTEM
REAR WINDOW LIFT                             ELECT CONTR RR WINDOW LIFTER + LOCK SYSTEM
DRIVER’S WINDOW LIFT                         SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT                      ELEC CNTRL PASS FRONT WINDOW LIFTER
DISPLAY                                      DISPLAY (RADIO+CLOCK AND OR TEMP, CD)
CLOCK                                        NUMERIC CLOCK
OIL GAUGE                                    OIL TEMP + LEVEL INDICATOR
HEATING ELEMENT                              NON HEATED SEAT
FRONT LATERAL AIRBAG                         WITHOUT FRONT SIDE AIRBAG
PASSENGER AIRBAG                             PASSENGER AIRBAG
ON-BOARD COMPUTER                            COMPUTER
EQUIPMENT PACK                               W/O EQUIPMENT PACK
EXTERIOR REAR VIEW MIRROR (HEATED)           HEATED DOOR MIRROR
AIRBAG DEACTIVATION                          MANUAL AIRBAG DEACTIVATION
INTERIOR DOOR CONTROL (APPEARANCE)           CHROME FINISH INSIDE DOOR HANDLE
FRONT SEAT GUARD                             WITHOUT CAB PROTECTION PANEL
FRONT SUN VISOR                              DRIV+PASS SIDE (W/O NOTICE)
RADIO RECEIVER                               "RD3" RDS COMPACT DISC AUDIO SYSTEM
REFRIGERATION                                AUTOMATIC AIR CONDITIONING
CRUISE CONTROL                               WITHOUT SPEED CONTROL
DRIVER’S SEAT HEIGHT CONTROL                 PARALLEL DRV HEIGHT ADJ
RHEOSTAT                                     RHEOSTAT
STORAGE (OTHERS)                             STORAGE COMPARTMENT FR + RR DOORS + WALLET
CARPET COVER                                 W/O CARPETMAT
DRIVER AIRBAG                                DRIVERS AIR BAG
LOAD SPACE STORAGE                           WITH BOOT TIDY
CARPET                                       F550 PILE CARPET
LIGHTING TIMER                               NOT ADJUSTABLE TIMER
SWITCH                                       ELECTRONIC ANTI-THEFT KEY
TRIM ADAPTATION                              PLAST GAIT+ LEATH G/KNOB + BLACK INSERT ALU MA
EQUALISER AMPLIFIER                          WITHOUT EQUALISER AMPLIFIER
LOCKING CONTROL                              SIMPLE CENTRAL LOCKING
STEERING WHEEL                               LEATHER STEERING WHEEL 3 BRANCHES
STORAGE SPACE LOCKS                          BOLT ON GLOVE-BOX
Electrical
ALTERNATOR                                   ALTERNATOR 70 AMP
HORNS                                        HORN STANDARD
BATTERY                                      BATTERY LO 250
STARTER MOTOR                                STARTER MOTOR CL 2
SPECIAL LIGHTING                             AUTOMATIC HEADLAMP ILLUMINATION
MULTIPLEXING                                 MULTIPLEXING ASSEMBLY
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION                        STANDARD
ATMOSPHERIC CONDITIONS                       NORMAL ATMOSPHERE
FIRST AID KIT                                FIRST AID KIT PACKAGING
RADIO HEADPHONE SOCKET                       WITHOUT ACCESSORIES SOCKET
SIDE IMPACTS                                 DOOR WITHOUT REINFORCEMENT
SET OF KEYS                                  1 HF PLIP KEY + 1 SINGLE MAIN KEY
SURFACE CONDITIONS                           GOOD TERRAIN
SPEED MONITORING                             WITHOUT SPEED CHECK
EMERGENCY WARNING TRIANGLE                   WITHOUT WARNING TRIANGLE
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
