I have a 2002 206 SW HDI 90 D-Turbo, the present problem is the Manual gear shift, I does not centre on its own and is very "Floppy" for want of a better word.
I have looked underneath the car and all the linkage is attached, but I was surprised to find that there are no springs or from what I can see any where to mount any to centre the Lever.
I am more used to RWD vehicles and in their case there are generally springs fitted internally to centre the gear lever.
I appreciate that the linkage on the 206 is external so centering the gear lever may rely on a different system.
If anyone can shed any light on what system Peugeot use to achieve this on a 206 HDI 90 I would be grateful.
The fact that the Gear lever stays where it is left is really irritating.
All suggestions gratefully received
Posted: Sun Nov 30, 2025 7:50 pm
The linkage is attached on top of the gearbox, under the battery. Off the top of my head i think there are 3 linkages. It sounds like one of them is loose or broken.
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
