Posted: Wed Mar 31, 2010 1:52 pm |
i see mate,
may get one custom built out of stainles steel
| Renault Clio III RS - Race Car
Former Poverty 206 XS 1.6Turbo Owner  | |
Posted: Wed Mar 31, 2010 3:58 pm |
After all this stuff I hope you're going to invest in some half decent trackday tyres
Posted: Wed Mar 31, 2010 4:09 pm |
| Seb wrote: |
After all this stuff I hope you're going to invest in some half decent trackday tyres  |
That will be the job for James he worked in the tyre industry for some time im sure he will know what tyres are best
Posted: Wed Mar 31, 2010 4:37 pm |
Make sure you have suspension capable of working slicks if
you get them!
Posted: Wed Mar 31, 2010 4:40 pm |
Aye, going to upgrade my bilsteins, to maybe B6 i think they are, they should do, i hope.
Posted: Wed Mar 31, 2010 4:46 pm |
i thought that the B6s were top dog for the 206s??
Posted: Wed Mar 31, 2010 5:43 pm |
You'll need a vastly increased spring rate to run slicks
Posted: Thu Apr 01, 2010 1:24 am |
| Jamie wrote: |
| You'll need a vastly increased spring rate to run slicks |
Does that mean Softer springs?
Posted: Thu Apr 01, 2010 1:46 am |
Higher spring rates = stiffer springs.
Posted: Thu Apr 01, 2010 3:37 am |
are sportlines stiffer than pro lines?
Posted: Thu Apr 01, 2010 7:09 am |
You wanna be looking at a 350-400lb spring at least to be honest, which I think the Eibachs are about 280?
Posted: Sun Apr 04, 2010 5:37 pm |
Posted: Mon Apr 05, 2010 8:35 am |
haha ........ and what are these little mods mattie??
Posted: Mon Apr 05, 2010 8:55 am |
| Mattie® wrote: |
| addaz wrote: |
Dude, can your car is now on my sexual metal list
Even if it is low pressure  |
Low Pressure whats that? |
Low pressure boost from a lack of uprated internals to hold large amounts of boost
For example if you where to turn up the Bar it would all end in tears
| Team Impossible Possible
Posted: Mon Apr 05, 2010 10:00 am |
| addaz wrote: |
| Mattie® wrote: |
| addaz wrote: |
For example if you where to turn up the Bar it would all end in tears  |
It certainly would, but with a change of compression ratio this will be delt with, No low boost for me
