Forums › Tuning, Modification & Legal › Project Cars › Briant's 206 rallycar build loads of pics |
Posted: Sun Sep 02, 2012 5:01 pm |
Schumi wrote: |
Nice progress Brain. But your inlet ports looking small to me. Which inlet system you will use.
I think you need GTI180 inlet manifold gasket for measurement and port match. |
im using jenvey tb's & inlet manifold supplied with kit from Mtech i ported the inlet manifold as much as i could and matched the ports in the head.
my engine has rubber seals on inlet manifold so were no good for measurments
have you any pics or measurments from 180 inlet manifold ill go bigger if i can
i need all the feedback/info i can get cant afford to send out or purchase a cyl head already ported so hoping to do work myself
Posted: Mon Sep 03, 2012 3:23 am |
Actually I have better photos of ports but I cant find now. If I remember when I go home tonight i will send much more photos.
And you will be suprise how exhaust ports bigger on gti 180. I will send exhaust ports photos to.
| 2005 206 RC RED
Lot's of CNC machined customs pars. | |
Posted: Mon Sep 03, 2012 4:30 am |
This is looking good! And I'm loving the colour choice! Good job so far!
Posted: Mon Sep 03, 2012 6:22 am |
I wouldn't use the gasket to match the ports until you are 100% certain it matches the inlet.
Posted: Mon Sep 03, 2012 6:23 am |
Edward wrote: |
I wouldn't use the gasket to match the ports until you are 100% certain it matches the inlet. |
could port the inlet at the same time?
Posted: Mon Sep 03, 2012 6:31 am |
I'd use a cardboard template to see how the ports compare to each other.
Posted: Mon Sep 03, 2012 2:14 pm |
| 2005 206 RC RED
Posted: Mon Sep 03, 2012 2:29 pm |
These are the Longman inlets...how do they compare to yours?
Posted: Mon Sep 03, 2012 3:06 pm |
Fairplay Richard longman gives good head!
| PEUGEOT 206 V6 FOR SALE !!!!
as seen on YOUTUBE
TEXT ME ON :07528810462 | |
Posted: Mon Sep 03, 2012 5:47 pm |
some great pics & info thanks to all
I ported up the inlet manifold bolted it on & was able to mark cyl head through the manifold to get exact match ill compare pics to the longman head to see how it looks,
@Schumi i havent opened the exhausts as much as my exhaust manifold isnt as big as gasket so i matched cylinder head to ex manifold with made up gasket/cardboard
now im thinking my manifold(raceland stainless) is not good enuf if i can open ports more id need to get a better quality manifold to make full use of bigger ports
Posted: Tue Sep 04, 2012 2:18 am |
Although I didn’t port mine myself I got some cardboard and placed it on the face of the head. Then mark out where the ports are – then cut the holes in the cardboard. Then place this on the inlet manifold to show you the size of the ports.
Posted: Tue Sep 04, 2012 6:33 am |
I didnt send final stage of ports. Today I hope i will found photos on my external drives.
| 2005 206 RC RED
Posted: Thu Sep 06, 2012 6:58 pm |
Posted: Mon Oct 15, 2012 5:44 pm |
Posted: Mon Oct 15, 2012 7:46 pm |
Forge bits look so sexy it's a shame you can't see them lol. Good progress lovin the work.
