Latest: heikkisj
Overall: 17126
Online Now [56]:
Visitors: 55
Today: 6396
Total: 100315805
Go to page Previous  1, 2, 3, 4 ... 9, 10, 11  Next
briant
PostPosted: Sun Jan 02, 2011 1:42 pm Up
macj wrote:
love it...... will be a treat to drive with the wider track
Cheers mate its taking way too long to build tho but should be worth it when finished Very Happy
206 Rallycar
macj
PostPosted: Sat Jan 08, 2011 4:42 am Up
BTW if you know where else to get a rear tailgate glass apart from P4P then let me know... I cant get an answer from them
briant
PostPosted: Fri Jan 21, 2011 6:04 pm Up
I got complete window kit from P4P was a bit of a wait for it to arrive but very happy with quality
quick update:
finished off all interior wiring,fitted internal fuel lines,fitted all pipe work and jets for fire extingusher,
got my dash back from flocking and have it fitted
camera batt flat will post pics later
206 Rallycar
macj
PostPosted: Sat Jan 22, 2011 4:22 am Up
Your on the good bit of the build now.... Its nice when it all starts to go back together
briant
PostPosted: Tue Jan 25, 2011 5:57 pm Up
Few pics of progress
Dash trimmed down and test fitted
[/img]
Fuel lines & fire ex pipework fitted
Dash Flocked and fitted
206 Rallycar
macj
PostPosted: Sat Apr 09, 2011 1:39 am Up
For some reason I seem to have missed this last posting... looking good mate... where are you now with it?
Uz
PostPosted: Sat Apr 09, 2011 2:24 am Up
Nice meeting you today Brian Smile
The Turinis and Chronos will suit this right down to a tee Thumb Up
Looking forward to seeing this finished.
Mr_Cellexe
PostPosted: Sat Apr 09, 2011 2:38 am Up
very nice, im currently at the stage you were in 2010! lol. im not rushing to finish tho Wink
briant
PostPosted: Tue Apr 12, 2011 3:50 pm Up
Cheers for comments lads
I have made small bits of progress since got engine fitted and started making loom,
got myself a heated windscreen and wheels
plan is to get few hours this week to finish looms
no real pics but will post up a few soon
206 Rallycar
briant
PostPosted: Sun Nov 27, 2011 10:06 am Up
I sort of had lost interest in this for while but after break away from it i got stuck in again
I took back out orignal rear axle i got a 206SW rear axle but it had drum brakes, so i converted it to use 288mm front discs used the callipers from front brake kit i had and widened the track of axle by 160mm,removed the orignal anti roll bar and fitted adjustable ARB and finally fitted alloy Peugeot Sport axle bushings.
Other bits done are
Front driveshafts are now sorted and fitted
Peugeot Sport sump guard fitted
Fitted Front Heated windscreen & 1/4 windows
have set a deadline to do my local Tarmac Stages Rally at end of Feb so will have regular updates on this Laughing
next on list is finish bodywork then engine & gearbox rebuilds
here are a few pics of progress
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
206 Rallycar
macj
PostPosted: Sun Nov 27, 2011 10:14 am Up
Its coming on nicely mate..... very big brakes on the rear Shocked
PostPosted: Sun Nov 27, 2011 12:24 pm Up
Love how clean and bright the boot floor is...what's the rules on having a cable operated hardbrake on the rear?
macj
PostPosted: Sun Nov 27, 2011 12:47 pm Up
It has to lock the wheels on the operation of the lever and remain locked with the hand removed from the lever. The usual way round it on a hydraulic handbrake is to fit a pin in the lever to hold it on
briant
PostPosted: Sun Nov 27, 2011 12:57 pm Up
What He Said
206 Rallycar
Brian
PostPosted: Sun Nov 27, 2011 1:09 pm Up
Trade Rating: +31
simply stunning Smile
Page 3 of 11
