Posted: Fri Feb 04, 2011 5:06 am |
Im sure this has been covered before but i couldnt find it... Dam Search..
All i want is a multiline display which says the temp, date and time...
ATM all i have is the clock which sucks..
I have a PrePlexed. 2000 'W' HDI...
Is it possible..
| Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
Posted: Fri Feb 04, 2011 5:33 am |
Yes.
If you have a clock at the minute, you'll have a PPT-20 connector. When you get a multi-line display it will have a PPT-30 connector, so you will need to wire that in, along with the temp sensor.
Posted: Fri Feb 04, 2011 5:59 am |
Thanks Lee, Where does the temp sensor wire into?
Posted: Fri Feb 04, 2011 6:21 am |
Pins 14 and 15 on the MFD according to the wiring diagram
Posted: Fri Feb 04, 2011 7:16 am |
Ok thanks,
Im guessing i can mount the sensor anywhere?
Posted: Fri Feb 04, 2011 7:39 am |
The sensor is built in to the passengers wing mirror, the little nipple on the bottom
