Latest: Andyblue64
Overall: 17123
Online Now [272]:
Visitors: 271
Today: 89889
Total: 98913888
Forums › The Car › 206 Talk › Driveshaft for a 180
206de
PostPosted: Tue Aug 03, 2010 1:04 pm Up
Does anybody know if a GTi 138 driveshaft will fit my 180?
I found some driveshafts for a gti in the link below and not sure if maybe one of those will fit the 180?
www.driveshaftstore.co...eModelYear
If not, can anybody point me in the right direction of where to get a driveshaft online for my 180? Smile
I'm after the passenger side one (the shorter one)
2005 Obsidian Black GTi 180 | Front -50mm Eibach Suspension | Rear Torsion Bar Lowered -30| SP Grille | Gloss Black Vortex Alloys
PostPosted: Tue Aug 03, 2010 2:43 pm Up
The shafts are the same.
206de
PostPosted: Tue Aug 03, 2010 4:30 pm Up
Ok, cheers Edward
