Latest: DanDan17
Overall: 17128
Online Now [61]:
Visitors: 60
Today: 33244
Total: 100508007
Forums › The Car › 206 Talk › Wiring Angel's
Wiring Angel's
PostPosted: Fri Aug 13, 2010 3:30 pm Up
Have a set of black twin ultra angel eye's which need fitting, they already have the h4 adaptor fitted which is ideal (thanks Wiliam Morgan) but they also have 3 red and 3 black wires attached to each headlight, I know if i remember correctly that the 3 red's connect to the sidelight wiring but where do the black wires go? If there is anyone in Plymouth area who is an electrician or knows exactly what there doing PM me as I'm wanting to fit these asap but i'm not confident enough to do it myself
PostPosted: Fri Aug 13, 2010 3:32 pm Up
Are the blacks ground wires?
PostPosted: Fri Aug 13, 2010 3:34 pm Up
Maybe I fu**** mine up terribly but I wired both to the sidelight like a parallel circuit.
PostPosted: Fri Aug 13, 2010 3:36 pm Up
I don't know mate, when it comes to wires etc i'm not very intellectual around it
puglad
PostPosted: Fri Aug 13, 2010 3:42 pm Up
Hi, Red goes to The side light and Black goes to ground
+2 Positive Feedback
eBayer seller 206 GTI Spoilers, £120 Colour coded Inc Post!
ModifiedJunkies Performance Parts Centre
Proud owner of a french motor
PostPosted: Fri Aug 13, 2010 3:49 pm Up
So you mean that all 3 black wires can just be secured to a bolt or bare metal bodyork and then I assume there are 3 sidelight wires for the 3 red wires?
puglad
PostPosted: Fri Aug 13, 2010 3:53 pm Up
Get me a pic of the angel wiring or which angels are they and i'll look them up mate Smile
DeadEyePaul
PostPosted: Sat Aug 14, 2010 5:58 am Up
black wires to the (-) and red wires to the (+) (before you connect it though make sure you test it on the battery termals) because i dont remember after your sure which is positive wire both(+/-) to sidelights
Mattie-RS
PostPosted: Sat Aug 14, 2010 6:33 am Up
Red is +
Black is -
Connect both to your side light.
Your side light will have 2 wires, the green and yellow one is - Connect all 3 black wires to this,
The other wire, can be any other colour, typical french wiring, is + Connect all 3 red to this.
Jobs a good'un
