Forums › The Car › 206 Talk › Gear box oil question |
Posted: Thu Aug 26, 2010 5:47 pm |
Posted: Fri Aug 27, 2010 12:25 am |
Iirc that Should do the job, and you don't need a gasket on this type of plug that I can rember Of
Posted: Fri Aug 27, 2010 1:02 am |
I recall 75/80 being the correct grade. I put a different grade on once and the gearchange felt awful.
