Posted: Wed Sep 01, 2010 9:11 am |
How is it done?
Can I just take away the compressor and leave the pipes there? r does the lot got to go?
Does it matter if I cut through one of the pipes and leave the other half there?
etc.
Posted: Wed Sep 01, 2010 9:12 am |
tomd0801754 wrote: |
How is it done?
etc.  |
The aux belt wont fit if you remove the air con
Posted: Wed Sep 01, 2010 9:15 am |
You can replace it for an non-aircon aux belt. You've gotta take the lot out (engine bay) and have the air con discharged correct before you start any work.
What even if the belt and what it touches is left untouched?
Posted: Wed Sep 01, 2010 9:18 am |
What even if the belt and what it touches is left untouched? |
But isnt the bit the belt goes on to the compressor??
If your going to do remove the lot other wise there is no point.
Posted: Wed Sep 01, 2010 9:21 am |
Big_Rich180 wrote: |
If your going to do remove the lot other wise there is no point. |
There is when I have to find a way to get the intercooler pipes through it.
I may have to negotiate around it somehow as there is no way I can afford a new fan belt and have that fitted etc. as well as the rest of the thing done.
Posted: Wed Sep 01, 2010 9:27 am |
I may have to negotiate around it somehow as there is no way I can afford a new fan belt and have that fitted etc. as well as the rest of the thing done. |
Ah i see, i thought you were going for a 172 cup job with no aircon at all.
Posted: Wed Sep 01, 2010 9:32 am |
Ah i see, i thought you were going for a 172 cup job with no aircon at all.  |
Nope! Haha. Its getting to the point I just want it done now! Haha. Best go back out to the car and plan a new route!
Posted: Fri Sep 03, 2010 6:57 am |
So I couldn't just de-gas and remove this:
And blank off the two pipes?
Posted: Fri Sep 03, 2010 11:06 am |
Posted: Fri Sep 03, 2010 11:58 am |
it is possible to fit it without losing the aircon just takes abit more work
Posted: Fri Sep 03, 2010 12:04 pm |
discharge the r134a straight in to the atmosphere,its poof gas.do want you want with that thing.the planet will be ok for another few weeks i rekon.
Posted: Fri Sep 03, 2010 12:06 pm |
ali20six wrote: |
discharge the r134a straight in to the atmosphere,its poof gas.do want you want with that thing.the planet will be ok for another few weeks i rekon. |
real mature attitude
Posted: Fri Sep 03, 2010 12:14 pm |
if your gay or a tree hugger i apologize,but the advice is sound,r134a is a safe gas for the enviroment.
Posted: Fri Sep 03, 2010 12:22 pm |
i let some go ages ago when i change my brother engine and there was a green cloud in the middle of the street for about 15 mins
