Latest: tc.206
Overall: 17147
Online Now [63]:
Visitors: 62
Today: 31182
Total: 116451265
Go to page Previous  1, 2, 3 ... 27, 28, 29 ... 31, 32, 33  Next
macj
PostPosted: Sat Mar 29, 2014 1:23 pm Up
Long Chat with Charlie yesterday regarding the new engine... here are his plans.
Newman or Piper 300 cams
Solid lifters
lash caps
Bigger valves
Knife edged crank
Billet steel flywheel
The idea is to build a reliable and strong engine that is capable of revving to 9000rpm. The power needs to be between 4000 and 8000rpm. The targets are. 250BHP and 220Nm of torque with a nice flat torque curve to suit the Sadev sequential box. The engine should still be ready for FCS after mapping at Mtech in Wiltshire.
jonsully
PostPosted: Sat Mar 29, 2014 1:26 pm Up
Mental!!The car will be awesome Smile
2000 gti 138,tein superstreet coilovers front,tein adjustable shocks rear,22mm rear arb,carbon fibre strut brace, 6 point omp cage,fibre glass bonnet,polycarb windows,406 v6 brembo 4 pots,carbon Lorraine rc6 pads,brembo 307hdi front discs,406 v6 master cylinder,braided hoses all round,306 gti-6 brake reservoir,abs removed,4.9 cwp with 3j driveline plated lsd,compbrake quickshift,k&n filter with cold air feed pipe,4 branch mani,decat,sportex straight thru race system,mocal oil cooler,group n engine mounts,omp bucket seats,omp steering wheel,battery relocated to boot,4 point harnesses,15'team dynamics pro race 1.2 on Michelin slicks
macj
PostPosted: Sat Mar 29, 2014 1:28 pm Up
Lets hope so...... cant wait for the sequential box...... wont be built and fitted till Autumn Crying or Very sad
usher
PostPosted: Sun Mar 30, 2014 4:06 am Up
is this a new engine or more mods to the origional, how much more can you get lol
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
macj
PostPosted: Sun Mar 30, 2014 12:33 pm Up
This will be a vitually new engine. only the head, pistons, rods and crank will be from the old unit.... even the crank could get the chop if its worn or fails the crack test.
Schumi
PostPosted: Mon Mar 31, 2014 4:32 pm Up
Be careful with oil pump. It can be explode at 9000 rpm. Lots of French guys know this problem. My GTI180 Turbo friend lost oil pump 2 times.
2005 206 RC RED
macj
PostPosted: Tue Apr 01, 2014 12:44 am Up
Thank Schumi.... how did they get round the problem
Schumi
PostPosted: Tue Apr 01, 2014 2:26 pm Up
They are using French Engine Specialist RDM companys oil pump. But they dont supply any part. Just turn key complete engines. Best EW engine come from RDM. Some second hand oil pumps on sale. But no one open and take picture from inside. What is upgraded. Also xrallyparts can supply oil pump but nearly 900 euro.
Peugeot 207 S2000 with EW10J4S also using wet sump as same as our engines. But that oil pump almost 2500 €. I will gone to dry sump setup.
This company sell dry sump setups. Thats a really solutions. Also lower height oil pan give much more clearance for safety at rally stages. Never oil surge on any corner or condition. But price to much. I cant remember how much. I ask last year.
www.a-e.dk/Motor-51115
2005 206 RC RED
macj
PostPosted: Tue Apr 01, 2014 3:36 pm Up
The pump and tank I have already but I cant find a dry sump pan for EW10J4 engine
PostPosted: Tue Apr 01, 2014 3:39 pm Up
I heard that Longman always fitted the EW12 pump to their engines...dunno why.
macj
PostPosted: Tue Apr 01, 2014 3:57 pm Up
would it be a slightly higher capacity or flow rate. I know that changing the spring rate increases a 137 pressure no problem
I might pull one to bits and have a look
Schumi
PostPosted: Tue Apr 01, 2014 5:26 pm Up
Thats true but non of engine builders dont know why he used EW12 one. Because there is no difference. Even Sandy Brown cant find why. Smile
2005 206 RC RED
macj
PostPosted: Sun Apr 06, 2014 3:57 pm Up
At last the championship shields have arrived Very Happy
AWK-53
PostPosted: Mon Apr 21, 2014 8:35 am Up
Any joy finding a sump pan? I've been looking for a dry sump kit as well but no joy. I emailed the company Alternative Engineering as linked above by Schumi but they no longer sell the kits.
macj
PostPosted: Mon Apr 21, 2014 10:32 am Up
I am looking a modding a standard sump pan. The idea being that you can cut out the majority of the ali pan and get a new plate welded in the bottom. Only problem would be distortion, meaning I would need to get the face skimmed
Page 28 of 33
