Latest: Andyblue64
Overall: 17123
Online Now [513]:
Visitors: 512
Today: 89781
Total: 98176975
Forums › The Car › 206 Talk › HDI 2.0 engine cover posts (mounts)
wifes206
PostPosted: Sat Jun 19, 2010 8:35 am Up
hi, i looked on the sevice box and as i need new engine cover mounts as the rubbers have pulled off the bolts
but there are two pat numbers
137F6 AND 13768
does anyone no which is the right one or has there been a upgraded part as i know these break alot
206 2.0hdi(04)
PUG91
PostPosted: Sat Jun 19, 2010 8:38 am Up
not too sure but if it's the parts I think you're talking about then I need them too, let me know if you hear anything
steevie_b
PostPosted: Sat Jun 19, 2010 8:41 am Up
0137.F6 are the new parts. £4.17+VAT each. I got some about a year ago and they still work fine.
QuArTz
PostPosted: Sat Jun 19, 2010 8:42 am Up
Trade Rating: +16
I have 2 engine mounts with caps for sale
4 posted?
wifes206
PostPosted: Sat Jun 19, 2010 8:43 am Up
how can you tell the new parts from the old ones?
how are they different?
206 2.0hdi(04)
steevie_b
PostPosted: Sat Jun 19, 2010 8:45 am Up
Well just by looking at them, the plastic on the old ones is white whereas the plastic on the new ones is black. Can't tell you more than that...
BaznPug
PostPosted: Thu Nov 04, 2010 9:23 am Up
With regard to the four engine cover clips that push on the rubber and metal vibration absorbers, Dont waste your hard earned on these four pieces of garbage because to keep on replacing them will either drive you insane or Max out your credit card OR BOTH.
If you are intent on retaing your Engine Cover you would be far better off to make your own clips, all you need is a couple of pairs of pliers and some stainless steel wire and four washers. with the Engine cover in place. Place the washers over the four rubber and metal vibration absorbers, cut and bend four pieces of stainless steel wire so they fit tightlyt into the grooves on the protruding metal pins. That has cost you just a little time, and if you have to replace them the next time you take off the engine cover in didn't cost a fortune either. I agree this doesn't look pretty but who has ever seen a pretty Diesel Engine?
Alternatively you can go to Ebay and purchase the eight pieces for £17 :( and the first time you use the clips they break again or just vibrate to pieces and you lose them. :oops:
PugnBaz
cartoonhead
PostPosted: Thu Nov 04, 2010 10:48 am Up
replaced mine so many times that now i just use a pice of 2" long hose pipe under the cover on all 4 holes and put a bolt thru the cover and hose pipe and just tighten it down till hose is all squashed up and cover is tight.
BaznPug
PostPosted: Thu Nov 04, 2010 12:17 pm Up
Yep, great Idea Cartoonhead.
It's crazy that such a simple thing cant be overcome when so many car manufactures use the same parts on so many models.
I'll see if I can come up with an innovative answer to the problem then present to "Dragons Den" for funding, lol Cool
PugnBaz
TomMessenger
PostPosted: Thu Nov 04, 2010 1:35 pm Up
I just used some bolts and wingnuts on mine, with a rubber sheath around it for vibration damping.
www.me-strings.co.uk - Day Job
www.tommessengerphoto.com - Occasional Job
tommessengerphoto.com/page7.htm - Fishy Stuff
