Latest: eniniex
Overall: 17113
Online Now [27]:
Visitors: 26
Today: 736
Total: 93816458
Forums › Tuning, Modification & Legal › Project Cars › PG Tips - Waste of Money, Effort and Time - 206 1.4 8v Turbo
Go to page Previous  1, 2, 3 ... , 36, 37, 38  Next
PostPosted: Sat Feb 28, 2015 3:38 am Up
Andrew wrote:
Awesome as ways
How did you route the reverse camera through the boot?
What do you mean mate? The camera is were the 3rd brake light is and i ran the leads through the seething were all the other wiring goes
PostPosted: Mon Apr 20, 2015 7:26 am Up
The 1.6 engine lives!
If anyone has me on facebook you can see the video there (adam chafer if you havent)
PezHdi
PostPosted: Mon Apr 20, 2015 10:34 am Up
Seen it Mate. Looks good Smile
EXL Pez
PostPosted: Mon May 18, 2015 6:32 am Up
Well this year is now out of the question...
oldskoolz
PostPosted: Mon May 18, 2015 7:21 am Up
Never a good idea to stash your cocaine in the engine bay Laughing
in all seriousness though what happened? cooling problem?
Black 206 Gti. Soon to be 2.2
PostPosted: Mon May 18, 2015 7:52 am Up
Not to sure what caused the fire but she went up in a big way Sad
oldskoolz
PostPosted: Mon May 18, 2015 8:14 am Up
man that sucks! don't let it get you down though, hopefully was just something small that was overlooked. either way I know she'll be back and stronger than ever
Vexs
PostPosted: Mon May 18, 2015 8:56 am Up
Damn man Sad was looking forward to seeing the changes at FCS.
Hppefully the extent of the damage isn't to bad!
My GTI 180
My Old 1.4 8v
samversteeg
PostPosted: Mon May 18, 2015 2:59 pm Up
Very unlucky Sad
Goodluck with the repairs!
frenchfrog40
PostPosted: Fri May 22, 2015 5:21 pm Up
Fwark! That not good mate. Hope its not too bad.
Iv had:
PostPosted: Sat May 23, 2015 2:31 am Up
Wow. That's not good but hopefully the expensive bits are salvageable. I've got an extinguisher in mine and I'm thinking of buying another too.
PostPosted: Sat May 23, 2015 4:25 am Up
I had one 1kg powder one, i highly advise two 2kg ones! And not powder! As it put it out but it just started up again!
PostPosted: Wed Jan 06, 2016 5:41 pm Up
I should really update this since its been half a year Laughing
Well what can i say?
Have i done loads?
No not in my eyes
What have i been doing?
Redoing everything Laughing I started fixing the bits that need attention and then ended up redoing most of it, one weekend at a time. Its getting close but its painfully slow process!
Whats left?
Fuel system, moving to PTFE aeroquip, building the mil spec loom (when i have the dam tools!), finishing of the relay board and then paint work again! Laughing
Is she changing?
Yes, very much so. She will be the first 206 to be done this way, and i hope to break the internet a touch when shes done!
Sim
PostPosted: Tue Jan 19, 2016 10:26 am Up
Now it's clear why photos from you are also classified, for now Very Happy
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
PostPosted: Sun Apr 03, 2016 2:55 pm Up
Also after speaking to a good engine building friend of mine, I just wanted to advise people on whoever are deciding to turbo-charge their 206 (TU specifically) that the plastic fuel rail is a danger waiting to happen!
Apparently my EGT probe was not working as it should have, so my thoughts of 500 or so degrees in the downpipe should have been closer to more 800 to 900 after a few high speed runs. The exhaust on the TU runs underneath the engine, and as we know heat rises, so hence why the fuel rail lifted in the centre and allowed the injectors to leak everywhere
Becareful fellow turbo TU owners!
Page 37 of 38
