Latest: elelectricistadeMateo
Overall: 17127
Online Now [64]:
Visitors: 63
Today: 829
Total: 100399067
Forums › The Car › 206 Talk › Are Seats / Door Cards Interchangeable On All Years ?
adarmo
PostPosted: Mon Oct 11, 2010 4:08 am Up
Hi,
Just bought a 206 and joined this site.
My car (1999 5dr) has burns on the seats and I've seen a set for sale but they are from a 5dr 2003.
This means its from a facelift car so will the seats / cards fit ok ?
Some sellers say they will, others say they won't.
Mark
PostPosted: Mon Oct 11, 2010 4:14 am Up
Yes & no, you can't put a 5 door interior in a 3 door 206 because the front seats don't fold forward. Also note that 3 door interior door cards wont fit a 5 door & vice versa.
TomMessenger
PostPosted: Mon Oct 11, 2010 4:19 am Up
But what if both models are 5d?
www.me-strings.co.uk - Day Job
www.tommessengerphoto.com - Occasional Job
tommessengerphoto.com/page7.htm - Fishy Stuff
PostPosted: Mon Oct 11, 2010 4:30 am Up
Then its fine. Also note that some models have side/seat Airbags. Does yours?
adarmo
PostPosted: Mon Oct 11, 2010 4:36 am Up
I thought it was likely they would fit just wanted to check they hadn't changed the door handle position or fittings etc.
I'd already figured out the 3/5dr problems and as the current interior is green I want rid of the lot !
Mark
VorTechS
PostPosted: Mon Oct 11, 2010 4:42 am Up
Staff - Vortechs
There may be some issues with the doorcards just to warn you.
I have a 2000 5dr, and got a replacement door. I wanted to keep the doorcard from the old door as it was in better condition. However, the door lock popup sits much higher than it did with the original doorcard.
It's minor, but can cause 'bounce issues' on occasions - but I'm guessing easily fixed if you can get the plastic off the top and hacksaw a bit of the rod off. (Haven't tried, as it doesn't bother me that much)
No problem.
It would be worthwhile investing in a number of trim clips from Peugeot, they are around £5 for 30. You will break some Wink
Part number for the clips is 6991E8
There is a guide on how to do so here.
206gti.net/doortrim/
adarmo
PostPosted: Mon Oct 11, 2010 4:46 am Up
Cheers
Oh and neither have airbags (poverty spec 1.4, its my daughters first car)
I have noticed the newer rear seats have the central shoulder seat belt built in, I presume that will work ok as it would be a nice upgrade over the lap belt.
Mark
PostPosted: Mon Oct 11, 2010 4:49 am Up
adarmo wrote:
Cheers
I can't see why not Smile
