Online Now [1297]:
Visitors: 1297
Today: 316925
Total: 151435743
Forums › The Car › 206 Talk › which wire?
which wire?
Forum Index › 206 Talk
davidmonkey
PostPosted: Thu Oct 14, 2010 3:48 pm Up
hi i have t 206 preplex can anyone tell me which wire that goes to the interior light triggers the light when i unlock the car or where the door pin switch is please
1.4 8v
PostPosted: Thu Oct 14, 2010 3:49 pm Up
The BSI earth, cant remember the colour of it and i cba to get up to look Laughing
If you look at it you could probably work it out, or just probe with a multimeter.
davidmonkey
PostPosted: Thu Oct 14, 2010 3:53 pm Up
does the wire switch earth to trigger or live
1.4 8v
PostPosted: Thu Oct 14, 2010 3:55 pm Up
The interior light has 4 wires
Constant +12v
Ignition wire
BSI earth
Earth
The door opening circuit uses the constant +12v and the bsi earth, it is the earth that activates the light. So what ever you are doing, use that as your earth
davidmonkey
PostPosted: Thu Oct 14, 2010 3:59 pm Up
ok thank i was gonna try putting some foot well neons in i wanted them to light up when i opened the door
1.4 8v
Rob2859
PostPosted: Thu Oct 14, 2010 6:54 pm Up
I have just done the same. Easiest was is to wire them to live on the radio (not the perm live the other one) They come on when you unlock the car then stay on until 3 mins after you lock the car. Very Happy
Afro206
PostPosted: Thu Oct 14, 2010 8:06 pm Up
When I wired some LED's into the door opening circuit, I just used the wires in the right-hand A pillar and spliced the wiring into them.
I checked which wires were which by pulling out the courtesy light, removing the plug and touching the LED's to the pins on the plug whilst the doors were open, then just found the same wires further down in the pillar.
2001 206 1.1 Look, Sports front/rear bumpers, White 205 Speedlines, Phase 2 Crystals (Soon!)
davidmonkey
PostPosted: Fri Oct 15, 2010 12:25 pm Up
thanks for the help could you tell me one last thing which side do the interior wires run down inside the pillars
1.4 8v
Afro206
PostPosted: Fri Oct 15, 2010 12:36 pm Up
If you were in the drivers seat, it would be the pillar on your right hand side.
davidmonkey
PostPosted: Fri Oct 15, 2010 1:41 pm Up
thanks very much
1.4 8v
