Online Now [722]:
Visitors: 722
Today: 108845
Total: 150186284
Forums › The Car › 206 Problems › Serious starting issues!
Go to page Previous  1, 2, 3
AusScare
PostPosted: Thu Nov 04, 2010 5:27 am Up
My car was doing this, turned out to be the fuel pump.
However I am still having intermittent start problems, just long turnovers, so I might ditch my NGK spark plugs and get some bocsh ones.
MY03 206 GTI Rallye
dannyboiii
PostPosted: Thu Nov 04, 2010 6:20 am Up
I've already changed the fuel pump, cleaned the Idle Control Valve, oil change, filters changed, new plugs (NGK). my mechanic said he ran a diagnostic on it and "cleared" some codes and now he thinks it could be the throttlebody, dont know if hes guessing or not though, cant afford to throw cash at it if its not gonna fix it.
2001 1.4 8v petrol
PostPosted: Thu Nov 04, 2010 7:51 am Up
dannyboiii wrote:
Lee wrote:
You had a diagnostic scan?
mechanic that checked it over first time said he had a diagnostic scan done and said it gave a few codes but he "cleared them" no idea what codes they were though so was thinking about taking it to have it done myself so i can see these codes.
Clearing the fault, doesn't fix the problem.
The problem needs to be fixed then the fault will be cleared.
You need a scan really and then that will help you narrow down the problem.
dannyboiii
PostPosted: Thu Nov 04, 2010 11:38 am Up
indeed, thats the plan of action for tomorrow, got my MOT this month too Shocked
2001 1.4 8v petrol
macj
PostPosted: Thu Nov 04, 2010 1:34 pm Up
Did you change the ETS
dannyboiii
PostPosted: Fri Nov 05, 2010 9:07 pm Up
not yet mate, changing it sunday, then a diagnostic test on it monday
2001 1.4 8v petrol
dannyboiii
PostPosted: Wed Nov 24, 2010 7:49 am Up
Changed the ETS and no success so booking in for diagnostic test
2001 1.4 8v petrol
retta
PostPosted: Fri Nov 26, 2010 10:17 am Up
I'm having exactly the same problem with mine first thing in the morning, when the weather gets cold like now, on an 01 1400 8v too - having to rev it to keep it from stalling, but when it's started up properly it's better (apart from a flat spot when changing into 5th gear a few mins down the road, seems to lose speed/revs a bit for some reason..then it's ok again a min or two later..)
firedance 206 glx
wayne
PostPosted: Sat Nov 27, 2010 2:22 pm Up
i have the same problem with my 206 and it drinks petrol some one help. i have spent loads of cash. should have bought a new engine.
my 206 drink petrol can you help?
wayne
PostPosted: Tue Dec 14, 2010 10:10 am Up
as anyone fixed this yet????????????
Page 3 of 3
