Posted: Mon Oct 18, 2010 2:27 pm |
Im looking at replacing both outer cv boots and both lower wishbones.... has anyone replaced these, and are there any awkward bits I should be aware of before I get the old tools out?
| Gti 180, 04, Janspeed cat-back system, viper induction. | |
Posted: Mon Oct 18, 2010 2:36 pm |
replaced the boots well tbh its was easier and cheaper to buy a second hand drive shaft lol and put that in then change the boots,
but thats my view you my find it easier to replace the boots,
make sure you have the right tools before you start and you will be fine a few hours work at most if you take it easy, you cant really go wrong
regards
Posted: Mon Oct 18, 2010 2:37 pm |
| wifey wrote: |
regards |
i agree
Posted: Mon Oct 18, 2010 2:48 pm |
| NorthantsBen wrote: |
| wifey wrote: |
regards |
i agree  |
at least i now know its not me just being xtra ha ha ha
Posted: Tue Oct 19, 2010 12:57 am |
I did a 'how to' on rebuilding the front suspension...it got lost when the old website crashed though. I shall have a think about making another one.
Posted: Tue Oct 19, 2010 5:42 am |
lower wish bones are not that difficult really, quite time consuming, getting the old pin out is a b***h, and then getting the new wishbones back in can be abit tricky. a mate and a big bar for leveridge is a good help to, oh and the drive shaft on the passenger side wanted to constatly fall out on mine!
