Forums › The Car › 206 Talk › Engine bay part numbers needed: With pics! + Advice needed! |
Posted: Fri Nov 12, 2010 10:13 am |
Trade Rating: +28
Just after a few part numbers and price for a few engine bay screws and other bits and bobs and also a little help
Part number and price for the jubilee clip (assuming they're all the same throughout the engine bay), air box screw, the bolt just below the right air box screw in the picture and the bolt that holds the grille in place, half out of picture bottom right of the picture:
Same again, the screws on top of the strut:
Same again for the bonnet catch, rusty screw visible above it, mushroom clip on top of the upper grille and the upper grille itself, as you can see to the left of the catch it's cracked:
Bonnet stay latch clip:
Rubber bonnet stoppers:
Rocker cover inc. bolts, badge and oil cap + Manifold cover inc. the 2 bolts either side and 1 in the middle:
Now, as you can see in the 2 pictures below I have a leak on the top of the rocker cover, been told it's common on these engines but wondered what others thought? an press the clip down and it's fine for a few days then seeps again?
I'm also after the part number for the cable tidy they use in the picture above, to keep the wires covered and together.
Finally, as you see below a lot of the plastics have dulled and in general it looks a mess, hence why I'm wanting to replace a lot of screws etc to keep it looking newer. What's best to clean it with? G101 at 10:1? To bring back some of the shine? I also have PB Natural Look but don't think it'd be suited for the grubby engine bay?
(A lot of the wires have been tidied away by the way )
Posted: Fri Nov 12, 2010 11:54 am |
I had the same problem with finding part numbers so i just went to a scrapyard and got all i needed for like a £5
Posted: Fri Nov 12, 2010 11:58 am |
Try service box maybe?
| 206 GTi 180 - 406 brembos with 283mm discs, coilovers and Sparco bucket seats | |
Posted: Fri Nov 12, 2010 12:19 pm |
Jubalee clip - 6981 L4
Upper grille - 7804 H5
mushroom clip - 6997 T2
light screw - 7427 23
strut screws - 5037 39
bonnet stays - 7928 31 & 7928 27
rubber stoppers - 7908 67
rocker cover - 0248 R3
oil cap - 0258 64
rocker cover screws - 0250 62
exhaust heat shield - 1426 Z7
screws for it - 6922 73
Could do with the VIN to double check the rocker cover, etc
Posted: Fri Nov 12, 2010 12:28 pm |
Don't replace the heat shield, Autosol it. The one below really is like a mirror. Be aware that a lot of the parts above will be in mimimum quantity orders. Such things like the hose clips are a minimum of 5.
Posted: Fri Nov 12, 2010 12:32 pm |
You can get all stuff like this from PoleVolt
Posted: Fri Nov 12, 2010 2:48 pm |
Aren't the air-box screws captive to the cover?
Don't know if its possible to change them separately..
Posted: Fri Nov 12, 2010 3:19 pm |
No they come out. Also the suspension top mount bolts come in packs of 20.
Posted: Fri Nov 12, 2010 5:34 pm |
Trade Rating: +28
Cheers for the numbers Lee, much appreciated! Will get them ordered soon
Was meant to PM you Edward as I saw a picture of yours with those covers on etc and meant to ask, cheers again
Posted: Sat Nov 13, 2010 2:46 am |
As for the bonnet catch, Just remove it and scrub it with a paintbrush and turps. They don't need adjusting when refitted as they will only go back in one position.
You can just about see my catch here. A quick scrub and all the old engrained oily grit comes off.
Posted: Sat Nov 13, 2010 3:08 am |
Trade Rating: +28
Cheers, saves a couple of quid!
