Latest: Andyblue64
Overall: 17123
Online Now [271]:
Visitors: 270
Today: 90226
Total: 98601539
Forums › The Car › 206 Problems › Tyre profile can i go from 55 to 50?
Go to page 1, 2, 3  Next
kenny16m
PostPosted: Sat Nov 20, 2010 11:22 am Up
I need a new set of tyres and im looking for a set of 195 55 15 are £330
But for the same make tyres but size 195 50 15 are £198
Thats saving me £132 thats alot of cash
Is it ok to reduce the profile size by 5? or will i have problems?
GT Dturbo
Team : Austin Healey Sprite
PostPosted: Sat Nov 20, 2010 11:25 am Up
Yes that would be fine I have done the same, speedo will be about 4mph out but its not a problem.
M60SHW
PostPosted: Sat Nov 20, 2010 11:26 am Up
No problems if your gettin all 4 and are they the same make and everything? Seams like a he'll of a hike in price lol
Team, ST
Team, Gti 138 track slag
Lecktorious
Trade Rating: +59
As Mikey said, knocks the speedo out ever so slightly but saves a small fortune!
'98 Nile Blue 306 GTi 6
kenny16m
PostPosted: Sat Nov 20, 2010 11:29 am Up
Was talking to a guy a while ago and he was saying that the 55 profile is quite 'rare' as alot use the 50 and thats why tyres are cheaper, i was just not sure what difference it would do
GT Dturbo
PUG91
PostPosted: Sat Nov 20, 2010 11:30 am Up
can you get your speedo re-calibrated or anything?
skard
i've been using 195/50's for over three years with no problem.
my 206 originally had 175/65/14's on. in my case, the 50's are actually closer to the overall circumference than 55's so affects my speedo less.
M60SHW
PostPosted: Sat Nov 20, 2010 11:38 am Up
You don't need to calibrate the speedo youl bearly notice anything And all speedos are out anyway Wink
Team, ST
PUG91
PostPosted: Sat Nov 20, 2010 11:40 am Up
So you have no excuse for speeding or something I heard?
rubyspilot
PostPosted: Sat Nov 20, 2010 11:48 am Up
When you change from 55 to 50 you will reduce the sidewall height by about 1cm.
This will reduce the rolling radius of the tyre by about 10cm.
Therefore the speedo will be 3.3% less than indicated.
IE when your speedo reads 30 you will actually be doing 29
when it reads 60 you will actually be doing 58
Maybe a slightly stiffer ride quality.......apart from that no problem.....
PostPosted: Sat Nov 20, 2010 12:01 pm Up
Will accelerate quicker too!
kenny16m
PostPosted: Sat Nov 20, 2010 12:40 pm Up
cool new set of rubber then before the snow comes in
GT Dturbo
xbonez182
PostPosted: Sat Nov 20, 2010 1:15 pm Up
195 50 15 for me too....i didnt know that profile set your speedo out but meh. its a slightly stiff ride compared to the steels i was on before
Locky
PostPosted: Tue Dec 14, 2010 4:57 am Up
Alright all, im glad i found this thread as have also been wondering about fitting 50s instead of 55s.
Slight evolution to the question as I already have 2x Pirelli P6000 195 55 15s but need 2 new tyres - so can I get 50's and run them ok with 55s? (obviously paired per axle)
If so, which is best to have up front?
2001 HDi D-Turbo, China Blue, Multiplexed.
panason1c
PostPosted: Tue Dec 14, 2010 5:02 am Up
Apart from a minor change to the speedo reading you will notice a slightly 'firmer' ride as the shallower tyre absorbs less of the bumps in the road.
Note...... use a sat nav, or similar, to check the speedo against the accurate sat nav reading
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
Page 1 of 3
