Online Now [1044]:
Visitors: 1044
Today: 57814
Total: 143255979
Forums › The Car › Request a how-to › how to remove rear brake callipers
Forum IndexRequest a how-to
meady
PostPosted: Fri Nov 12, 2010 1:33 pm Reply with quote Up
Trade Rating: +45
Right im trying to remove my rear brake callipers as hey are geting painted tomorow. The only problem is we cant get the handbrake calliper disconected. Does anyone know a good way to remove it cheers
TEAM - I HATE FACEBOOK Smile
meady
PostPosted: Fri Nov 12, 2010 4:10 pm Reply with quote Up
Trade Rating: +45
Sorry to bump this already bt i need to get them off asap please help
PostPosted: Fri Nov 12, 2010 4:22 pm Reply with quote Up
Don't remove the whole caliper. Just undo the 2x 17/19?mm bolts and pull the big C shaped bit off and get it painted.
PostPosted: Fri Nov 12, 2010 4:23 pm Reply with quote Up
Or paint them on the car! Wink
meady
PostPosted: Fri Nov 12, 2010 4:34 pm Reply with quote Up
Trade Rating: +45
howcome. The only probably with that is im taking thm sumwhere to get painted :s
PostPosted: Fri Nov 12, 2010 4:50 pm Reply with quote Up
Thats the only part that is really visable, otherwise you'll have to take the whole caliper off and bleed the brakes, Take a look at edwards Garage.
meady
PostPosted: Fri Nov 12, 2010 4:57 pm Reply with quote Up
Trade Rating: +45
Im guna have to bleed the brakes anyway as im changing the fronts to brembos at the same time
meady
PostPosted: Sat Nov 13, 2010 1:12 pm Reply with quote Up
Trade Rating: +45
All sorted now. Me nate managed to get the handbrake disconected and they are now down the shop getting painted
PostPosted: Sat Nov 13, 2010 2:49 pm Reply with quote Up
But they shouldn't paint the whole thing anyway...
meady
PostPosted: Sat Nov 13, 2010 3:07 pm Reply with quote Up
Trade Rating: +45
what you mean shouldnt paint the whole thing anyway ???
PostPosted: Sat Nov 13, 2010 3:35 pm Reply with quote Up
Because it's in 2 parts. There's a alloy block part with the piston and handbrake mechanism. This part doesn't need painting. There's also the C shaped section that's made from steel. That's the only bit that needs painting.
The gold part is the only bit that needs painting...
The rest of the caliper is alloy and doesn't need painting.
meady
PostPosted: Sat Nov 13, 2010 3:43 pm Reply with quote Up
Trade Rating: +45
well his son is a mechanic and he is down there most of the time so he should know that anyway, does it mater if the bit that dont need painting gets painted ??? cheers
PostPosted: Sun Nov 14, 2010 4:35 am Reply with quote Up
It doesn't matter if it gets painted but simply polishing it with autosol would have looked much better.
That also means you wouldn't have had the hassle of removing the brake pipe (and bleeding them afterwards) and handbrake cable!
meady
PostPosted: Sun Nov 14, 2010 9:51 am Reply with quote Up
Trade Rating: +45
Ah tht don't mata then because me mate os doin it all for me. The front brakes had to come off anyway as brembos arw goin on and im changing the master brake cylinder so its only a bot mre bleeding for him to do
  Quick Reply
Username:
Message:
Quote the last message
